should your post be titled "Output transformer secondary"?
It is normal to ground the common lead from the OT secondary, admittedly not ALL amps are wired like this, but more are than aren't. It is more likely that the heat you feel from the chassis is coming from the PT and/or power tube.
LinkBack URL
About LinkBacks
