Go Back   Music Electronics Forum > Music Electronics
Music Electronics General discussion about music electronics
Old 11-04-2007, 04:17 AM   #1
Tascam M-50, worth fixing?
I have a Tascam M-50 that I'd like to sell. My local pro-audio shop tried to test it, but it won't power up. Is it worth taking to someplace like Alex Audio in Crystal,MN, and having them fix it? Or do I pop it as a repairable? I have very little into it so far.
Tx!
s is for stuff is offline   Reply With Quote
Old 11-06-2007, 01:11 AM   #2
As a technician, the symptom of dead, no sign of life, is usually pretty simple to solve. Worst case is bad power transformer, which is least likely. In other words, most any competent repair shop could probably get it going.
Without looking it up somewhere, what is an M-50?
Old 11-06-2007, 01:44 AM   #3
It's a monster mixer. I've attached a picture of it. I've seen one for sale on the 'net for $800, and there's one listed in a store on ebay for the same price, but that's neither here nor there if they don't sell. If the thing's only worth a couple beans, I don't feel like lugging it around and spending time/money on it. I'm not lazy, just too busy...
Old 11-10-2007, 06:32 PM   #4
I was wrong . The unit does power up, but there's no signal coming through. So does that change anything? I've listed it on eBay titled "Tascam Monster Mixer M-50, needs work". Thanks for looking!
Old 11-10-2007, 08:08 PM   #5
Oh, not necessarily. DO NONE of the outputs produce ANY sound? All masters, all aux sends, all anything coming out? DO any of the individual channel peak lights work. DO any function indicator lights work?
If the thing lights up but still seems massively non-fuctional, I'd still think power supply trouble. Take the bottom off or otherwise access the innards and see if there is a loose connector or a blown fuse.
I don't have the schematic on this model, but as a service center I can get it easy enough.
If anything works, what?
Looks like a 12x8 recording mixer. Looks like the phones can monitor a selection of things. Feed a channel a signal, pot up the sends and see if the phones make any sounds.
If all 8 output channels are dead, but the input channel function, then I'd look still for power supply to that region or possibly a stuck mute line.
it still doesn't sound like a major deal to me, at least looking from here. The whole system is dead, which is still better than a lot of individual things wrong with all the channels.
Assuming we fix teh major problem, when it worked, how clean were the controls?
Lexicon LXP-5 - worth the effort??? Rob Mercure Guitar Effects 2 09-07-2009 06:52 AM
Tascam M-50 Mod Dave G. Music Electronics 0 09-11-2007 12:54 AM
Marshall DSL 100, need help fixing it. marshandall Maintenance, Troubleshooting & Repair 2 09-04-2007 09:23 AM
Supro 1688TN (What's It worth?) buckoeman Vintage Amps 1 03-06-2007 10:08 PM
Need help fixing a Marshall Lead 12 Combo steve Maintenance, Troubleshooting & Repair 8 11-24-2006 04:58 PM
