| | #1 |
| Junior Member Join Date: Nov 2007
Just bought a working 1965 (UK) Northcourt 30 head on ebay. I'm looking for schematics - particularly the spec on the main transformer - so I can replace the (looks hand wound) 220vac/50hz input transformer and use USA 115vac/60hz. Any suggestions? Days of searching have turned up nothing more than references to this mid-60's 'poor man's Marshall JTM 45' knock off - but no clues on where to get specs. |
| | #2 |
So if it is more or less a JTM 45, then look at the JTM 45 drawings. Ought to be close if that is the case. I assume the only real question is the B+ winding. Since the amp works, connect 220 to it and measure the voltages inside. The voltages on the secondary side will be the same regardless of 120/220. the 50/60Hz thing shouldn't make much difference. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Looking for Knox amp info | tonefreak | Repair and Restoration | 10 | 07-25-2008 08:09 AM |
| Info on this amp??? | Bernardduur | Maintenance, Troubleshooting & Repair | 3 | 09-13-2007 02:01 PM |
| fender pa 100 info? | digthisbigcrux | Mods & Tweeks | 4 | 06-14-2007 03:47 PM |
| RoHS info | soundmasterg | Pickup Makers | 3 | 04-23-2007 08:28 PM |
| I am looking for some cab info for my ga5? | john t | Repair and Restoration | 0 | 01-18-2007 03:42 PM |
