Go Back   Music Electronics Forum > Instrumentation > Guitar Tech > Pickup Makers
Old 08-13-2006, 01:43 AM   #1
Piezo wire
Does anyone know a source for piezo wire for making undersaddle pickups?
jimi is offline   Reply With Quote
Old 08-13-2006, 02:09 AM   #2
It isn't a wire..
It is more like a laminated material. The more enterprising and cheap-ass experimenters(like me) have had hours of fun cutting up the gold-colored piezo speaker/transducer discs found in small electronic devices like games, phones, and alarm clocks. You can also just buy new ones at the local electronics emporium but that eliminates the fun of tearing apart a dead electronic do-hickey.
http://www.mcld.co.uk/oddmu/tincanba...transducer.jpg
an undersaddle transducer is essentially six little chunks of this material stuck together and wrapped with insulated shielding. The stick-on dime or quarter sized transducers are basically just a small transducer like the one in the link above stuck in a housing with epoxy.
Of course the better commercial pickups probably have slightly different formulas for their material, but that shouldn't be a deterrent to a cheap afternoon of fun, should it?
Sweetfinger is offline   Reply With Quote
Old 08-13-2006, 05:14 AM   #3
ken
ken's Avatar
How do you attach wire to them? I have an old friend who wanted a violin transducer made of this stuff.
Ken
ken is offline   Reply With Quote
Old 08-13-2006, 05:32 PM   #4
I mean piezo coax like headway pickups are made from. I have some from RS but they don't seem to have it now.
Old 08-13-2006, 09:11 PM   #5
With the disc material, I've always soldered right to the material. I imagine that the commercial six pc. ones are soldered all at once with paste or some similarly clever method.
as for coax wire, I'm guessing that it is some sort of high-tech sensing material for earthquake detection in Japanese buildings or something like that. Who knows? I'm sure that the LAST thing the manufacturer imagined was that it would be used in guitars. I could be wrong. I've never seen the wire material in any electronics hobby shop or parts catalog, but It's gotta be out there somewhere.
Old 08-13-2006, 10:55 PM   #6
Satamax's Avatar
Location: Southern french alps, right by the Italian border
Talking
Quote:
Hi everybody.
Jimi, it's NTK piezzo wire, i've looked on their site, but it's a busy one, so i didn't find much, i bet if you phone their importer into your country, they will most certainly be able to help. I'm more intrested into polyvinylidene film like pick up the world pickups.
Bye.
Max.
Satamax is offline   Reply With Quote
Old 08-14-2006, 05:24 PM   #7
Pickup Maker
David Schwab's Avatar
Here's some sources for piezo coax:
TC Lutherie, Piezo Materials
Measurement Specialties
Piezo Systems, Inc.
__________________
Those who create are rare; those who cannot are numerous. Therefore, the latter are stronger. - Coco Chanel
www.sgd-lutherie.com
www.myspace.com/sgdlutherie
www.myspace.com/davidschwab
David Schwab is offline   Reply With Quote
Old 08-17-2006, 08:16 PM   #8
Thanks for the links David that's useful.
I couldnt find any mention of coax on the NTK site.
Old 08-17-2006, 08:32 PM   #9
Pickup Maker
You're welcome.
__________________
Old 08-17-2006, 09:56 PM   #10
Satamax's Avatar
Wink
Hi Guys!
Well, sorry Jimi, it's the only brand i've ever had. There's a preamp that a guy designed on the MIMF, here's the only pic of the schemo i can link to, but if you register, you'll be able to look at all the schemos in the library.
Bye.
Max.
http://www.mimf.com/cgi-bin/WebX?50@...JI.0@.1dcf784d
Old 08-18-2006, 07:17 PM   #11
Pickup Maker
Quote:
I'm sure it was used for something like that originally... it's almost just very microphonic coax cable!
I believe Rick Tuner was the first to use it for guitars with his Highlander pickup. At least that was the first time I ever heard of the stuff.
I haven't used any of it yet, but I plan on building a piezo bridge for my fretless bass using it.
I read a tip on MIMF one day... the poster said he removes the braided shied wire, and then paints the core wire's insulator with silver conductive paint. He then wraps a bare wire around one end to make the shield connection. This makes the coax thinner and more flexible, and that makes the pickup more sensitive, and gives a higher output.
As I said, I haven't tried any of this myself.
__________________
Old 08-29-2006, 12:58 AM   #12
I've used piezo cable.
We had a piezo cable pickup at the music store where I work. It kept turning back up on the shelf. When I asked the guitar tech why it kept returning, he said, "It sounds like crap."
That interested me. I brought it home and put it in a cheap acoustic with a Fishman preamp/EQ and indeed, it sounded terrible.
But I was convinced that it was because it wasn't making solid contact in the slot. I put a thin strip of Mexican modeling clay under and over the rope, replaced the bridge, and strung it up. I gave it a night to harden, and low and behold, it sounds great.
The clay is easy to work with and if it has to be removed, it comes out easily as it is pretty brittle.
The rope, with the hardened clay, doesn't have the quackiness of most piezo pickups, including piezo film. It remains quite feedback resistant and works great with the EQ.
The guitar is a Vantage my boss bought for the case. He was going to throw the guitar away as he didn't think it was worth the time to set it up. It's turned out to be a thoroughly fine instrument when plugged in, and not too bad acoustically.
The piezo rope has it's possibilities. The clay idea came from an article titled, "Is Clay the Way" where the author used clay to even out the response of piezo pickups. I've found it to be helpful with some piezo pickups, and not good for others. The moisture in the clay can cause some shorting of some piezo chunk pickups...at least until it has dried enough.
Steve Dallman is offline   Reply With Quote
Old 08-29-2006, 02:18 AM   #13
I looked into it a few years ago. My understanding is that the use of this piezo coax as a guitar pickup is patented or licensed. I don't have a citation but somebody might know. Anyway, the manufacturer would not sell it for use as a pickup. Just for surveillance use. Its made to be buried and used as perimeter security. I'd be careful about putting it into anything for sale.
Its pretty noisy stuff. The plastic piezo dielectric isn't exceptionally springy. More squishy than springy. May work better (at the expense of output) if there was a secondary springy material alongside it. Never got around to trying that.
Just Bob is offline   Reply With Quote
Old 08-29-2006, 09:03 PM   #14
Pickup Maker
Quote:
I can't find a patent for a coax under saddle pickup, but I haven't looked at all of them yet.
Here's the Highlander pickup. They don't have a patent number listed anywhere on the site, so I think it's safe to assume they don't have one.
http://www.highlanderpickups.com/techspec/pickup.htm
__________________
Old 08-29-2006, 09:51 PM   #15
I did a quick search. "A transducer for a stringed musical instrument utilizes a coaxial structure. An electromechanical film tape is disposed about an inner, electrically conductive core. An outer conductor is formed about the electromechanical film tape. The electromechanical film tape may be provided as a piezoelectric polymer film" Patented by Fishman and it issued in 2004. #6,677,514 Also # 6,429,367 and #6,239,349. The piezo coax is actually manufactured by a spiral wrap of the piezo stuff around the core. Roughly 45 patents listed if you go to USPTO.gov and search on "coaxial AND piezoelectric and musical and instrument".
Others have the multi-element pickups patented and others have the electret transducers patented. So far as experimenting there's no problem. But, if you wanted to sell a product with this sort of sensor in it you'd need to be careful. Either license it or buy a ready-made sensor from somebody. Pretty much everything you can think up infringes on somebody's patent as I'm sure you know. Unless you stick to the tried-and-true stuff that has already expired. But, for the piezo saddle pickups that isn't real important to me since I don't really love the sound. Certainly convenient. Its a nice concept but the materials have issues. Noise, longevity, dynamic range, temperature, etc, etc.
Old 08-29-2006, 10:18 PM   #16
Pickup Maker
Yeah I saw those.. haven't looked through them yet. And some other interesting ones too. But you can see that Highlander sells them, and they were the first to market with an under-saddle coax pickup... been out since the mid 90's. I believe Rick Tuner designed the Highlander.
__________________
Old 08-30-2006, 09:14 PM   #17
Pickup Maker
OK.. I found the answer as to where and how the first piezo coax cable pickups were made... it's an interesting story!
Interview with Rick Tuner
Quote:
Tell me about the pickups you've designed for these Renaissance guitars, and how that design was developed.
Well, one day David Crosby comes into Westwood Music and says, "Turner, if you design a better way to amplify an acoustic guitar, and I don't get it first, I'll have your balls cut off." (laughter) So what are you going to do? It was something that needed to be done anyway, and I had already done work in that area for Gibson. One really great thing I had going for me at that time was that Jackson Browne basically put his studio at my disposal, which was incredible. If there wasn't a session happening I could go in and listen to anything, and record it to twenty-four track tape, and listen back. Some of the finest analog gear in the world is in his studio. So that was my sound laboratory when I was in LA. I'd go down to Jackson's and we'd try stuff all day, and record it, and listen back.
During this period I came across this passive-sonar-array technology, this coaxial wire. I'm good at finding things, and I'm good at talking to engineers at other companies and getting them excited about new applications for their products. You've got to be willing to jump out there. Now, with the internet it's amazing. You can find stuff pretty easily. Anyway, I find this stuff, and it looks pretty interesting.
Is it the wire that they trail behind submarines?
Right, and listen for Red October. It's a coaxial wire but instead of an insulator, what would be the insulator is rubber impregnated with piezo-ceramic dust. I stumbled on the material, and then worked with Bob Wolstein on its application. I had started working with Bob on hex pickups when I was at Westwood Music and doing the Gibson stuff. He is as fine an electronic-circuit designer as anybody I've ever met.
If the piezo material is impregnated in rubber, how does the signal develop.
Well, there's a center conductor and an outer shield with this stuff in-between. It develops a voltage potential between the center conductor and the outside shield, and it does so radially. One of the things that distinguishes the piezo-cable pickups from flat piezo pickups is that they give you vibrational input from the walls of the saddle slot and the saddle instead of just from the saddle, so they develop a signal more three dimensionally, where a flat piezo responds more two dimensionally. The end result is a more complex signal. You couple that with Bob's electronics, which I haven't heard anyone beat, and you've got a very, very nice system.
We developed the Highlander pickup at Westwood Music and in Jackson's studio. My two contributions to it were finding the technology, finding the coaxial pickup material and working the deal with the company that makes it to get what we needed, and then, since most luthiers shouldn't ever be allowed to handle a soldering iron, nor to go anywhere near a fine guitar with a soldering iron, I came up with the idea to develop a packaging system that was soldering-iron-free, and that also took care of shielding and so on. I don't know whether it was Bob or me who thought, what if we could design it to install completely from the outside, through the end pin hole? Anyway, Bob said, "Oh yeah, I can do that." Of course, now the other pickup companies, Fishman, and so on, have knocked off this preamp-in-an-end-pin concept from Highlander.
Bob had started working on circuit design with computers at that point. He switched over from designing circuits in the traditional way to using computers in no time flat. The guy's a friggin' genius. He had circuit-simulator software, and he was able to write a program which set up the circuit for the preamp with all the parts values, and then it changed the parts values slightly and tested each virtual circuit just as though he was working with real-world parts. The amazing thing was that he was able to set his computer up to test 10,000 virtual circuits overnight! By testing all these variations he could determine the parts values we wanted. That makes a difference not only in performance, but also in how much the circuit is going to cost. You can get parts that are rated to various tolerances, 20% parts, 10% parts, 5%, 2%, and 1%, but the tighter the values are, the higher the cost. For instance, he discovered that the input-impedance-setting resistor was the most important resistor in the circuit in terms of noise, and the most important in precision in terms of reproducible results. So bam, that's a 2% part. Everything else can be 5%. Then he designed this long skinny circuit card that fit in a metal tube that soldered directly onto an end-pin jack, and bam, we were there! I wanted to call it a tube preamp, but that was taken (laughter).
So that was the start of Highlander. Bob and I were partners in that until my guitar making thing, which was starting to take off simultaneously, kicked in to the point where I just said, "Bob, we can be partners or we can be friends, but I can't start two companies at the same time. You take Highlander and do it." I've continued to use Bob as my primary supplier for electronic circuits, but he and Holly have taken the company and made it roll.
From http://www.renaissanceguitars.com/interview.html
__________________
Old 08-30-2006, 10:42 PM   #18
It is an interesting story. Some of the factoids are a little out of kilter regarding the piezo coax, but close. The stuff they use for intrusion detection (which is also used for saddle pickups) is not the same stuff they use on subs. You can't buy that on the open market. You also can't simply take piezoelectric particles and mix them with rubber. Particles would all have to radially align their sensitive axis with the core and the rubber would need to be somewhat conductive and other minor issues. I spent a good 20 or 25 years designing electronics and sensors for government use, including these kind of sensors.
The piezo coax you can get is made by wrapping a plastic tape around a wire core and applying a braided shield. The plastic (PVDF) is stretched to make it piezoelectric. Its made to bury in the ground or in concrete slabs and detect footsteps. Much less challenging than sonar. Anyway, the rest of the story is interesting.
The piezo coax is compressed into the saddle slot and you detect the volumetric compression of the coax. Whether that's better or worse than a flat piezo pickup, I couldn't say. The signal may be larger, but so is the noise because that piezo plastic is noisier than ceramic piezoelectrics. What matters more is the signal-to-noise ratio rather than just the absolute signal level. Anyway, can get too easily bogged down in all the technology when what counts is the sound. If it makes the sound you like, its good.
Old 08-31-2006, 08:47 AM   #19
ake
Piezo wire
another piezopickup made off piezowire http://www.headwayelectronics.com/
ake is offline   Reply With Quote
Old 08-31-2006, 04:01 PM   #20
Pickup Maker
Thanks for the info... very interesting.
Tuner claims that because the coax also touches the sides of the slot, it also picks up side to side motion, as well as the up and down stuff between the saddle and bridge.
__________________
Old 08-31-2006, 04:37 PM   #21
That's an interesting concept, but I'm not sure of the real necessity. Depends on whether you're trying for "accurate" sound or "good" sound. Any force on the bridge in any direction which causes compression of the coax will give signal. So, you're measuring stuff that does not necessarily contribute to the acoustic sound. Good? Bad? I'm not sure. The bridge tries to move every which way but the guitar top constrains it to move only in certain directions. The top radiates your sound. I would think that ideally the bridge is tight in the saddle and they move as a unit. A solid piezo sensor has a high modulus. It does not squish much under the force of the strings. Millionths of an inch. The piezo coax is much softer and does deform. Probably in the thousandths of an inch range. That will have some effect on the sustain and tone.
Anyway, the whole business of sensors is complicated. The sensor changes the instrument. It's really a different instrument when you put any sort of sensor on it. The sensor does not measure what you hear acoustically. A contact mic or soundhole or endpin mic does not hear what the player or the audience hears. The amp and speakers color the sound. You just configure the whole package and see if you like the sound.
Old 08-31-2006, 04:50 PM   #22
Pickup Maker
Very true. One interesting thing he says is that his Renaissance guitars sound more like an acoustic than most acoustics with under saddle transducers because his top doesn't vibrate under the bridge (he has a solid block under the bridge like an ES-335). His reasoning is the vibrating top will cancel out some bridge vibrations.
it is a complex situation.
I'm planning on making a coax under saddle pickup for a solid body fretless bass. I'm going to replace the metal Schaller bridge with a wooden or aluminum acoustic guitar style bridge.
__________________
Old 08-31-2006, 07:25 PM   #23
That sounds pretty cool. I never tried a piezo on a solid-body. A piezo transducer is basically a capacitor. It generates charge in response to strain. Any other capacitance in parallel with the sensor (i.e. cable) will form a capacitive voltage divider and reduce your available output voltage. Also, the input impedance of the preamp forms an RC filter with the pickup. The capacitance of that little piece of coax is probably only 2 or 3 pF. Ceramic piezo materials have a much higher dielectric constant. If you want good output on the low end (RC constant around 20 Hz), you need an input impedance for the preamp that's huge. Around 1e11 ohms. I'd do a MOSFET preamp right in the saddle. Don't know if you can do surface mount, but that's what I use for most stuff these days.
Piezo materials respond to strain. How much motion you need to get a certain strain depends on the modulus of elasticity of the piezo material. Ceramics are stiff but the plastic piezo stuff is soft. Probably also a good amount of hysteresis. You need a lot more actual motion. Piezo materials are generally used so they provide the restoring force (think springs) in a mechanical circuit. So, the trick is to constrain the bridge so it can't flop around too much but still put pressure on the piezo stuff. Maybe a tall Delrin bridge in a deep saddle slot. Or, something more like a hinge using stainless shim stock.
Old 08-31-2006, 08:12 PM   #24
Pickup Maker
I haven't used any surface mount stuff yet, but I am planning on using a FET or MOSFET based circuit.
I once saw an interesting project that used two pieces of copper clad circuit board with a thin piece of foam rubber in between that was used for an electronic drum pad. When you hit it, it changed the capacitance and the circuit that went with it produced a trigger pulse.
I'm going to make a bridge with some type of synthetic saddle, like delrin or tusq. The idea of using aluminum as the base (and maybe even the saddle) is it has a similar modulus as wood.
Turner does an interesting thing... he angles his saddle back about 13°, which is supposed to improve the pressure.
__________________
Old 09-01-2006, 02:48 AM   #25
Be aware that MOSFETs are very noisy as linear amplifiers, but make good switches. JFETs (and bipolar transistors) can be very quiet.
Joe Gwinn is offline   Reply With Quote
Old 09-01-2006, 12:56 PM   #26
Quote:
Yes, but there's a lot of art to this. MOSFET current noise can be very low and a piezo preamp needs very high input impedance. Designing a low-distortion MOSFET front end isn't the simplest thing. A fairly good off-the-shelf solution is an OPA129 opamp (available in surface mount for about $6). It has input bias current in the femptoamp range. As a non-inverting amplifier, the input impedance can be in the 1e15 area with noise voltage around 25 nV/root Hz. Rather high, but the larger signal available by using the high impedance makes the overall SNR at the output pretty good. With inverting amplifiers, the necessary feedback resistor is huge (over 10 gigohms) and is a trick in itself.
Layout for these sort of amplifiers is critical. Using .050 pitch SO parts, it is possible to hand solder if you're good. Smaller pitch is much harder, I did it for years before getting the hot-air equipment. I just tinned one pad for a component, then soldered one end of the part while holding it with tweezers. Once it's in place, the other pads can be soldered. Takes a little practice and best to try it before you've had 6 cups of coffee. A piezo preamp with the OPA129 only has about 5 parts. Could easily make it on a piece of PC board with a dremel. Around 0.2 by 0.3 inches. Solder the piezo coax right to the board.
Old 09-01-2006, 03:07 PM   #27
Pickup Maker
I generally use JFETs, both transistors and op amps, and some bipolar transistors... I haven't used any MOSFETs as of yet. I have a few circuits that use them that I have been wanting to try out, but I might just use an op amp anyway... also I've been wanting to try some of the nice audio op amps from Analog and Burr Brown.
__________________
Old 09-01-2006, 03:13 PM   #28
OK. The consequence of device noise dependes on where in the signal chain the device is used, and for what. MOSFETs used as variable resistors (versus amplifiers) or switches don't cause excess noise.
Old 09-04-2006, 10:25 PM   #29
I'm surprised somebody said this stuff sounds like crap. Maybe it's the type of wire used. I've played around with it a bit and to me it sounds really nice, very natural. I compared it directly to an EMG undersaddle pickup and it was miles better. I left the outer braid on. I use a simple preamp with a jfet and a transistor and had no problems with noise. In fact it's very quiet. It has a slightly lower output than usual so needs to be amplified more.
It's usually recomended to rout a half round groove in the bottom of the saddle slot for it to sit in although I didnt do this and had no problems.
I know of two companys that make pickups with it, Highlander and Headway in the UK so I don't know if there's any patent on it.
Old 09-05-2006, 02:35 AM   #30
Piezo pickups aren't really bad, they just tend to be a bit more noisy than I like. A lot of companies make them and they wouldn't sell if they were really bad. A lot depends on on your amp and speakers, of course. If you play through equipment meant for electric rather than acoustic, you may not hear any noise at all. I use flat studio monitors and no effects or compression or anything and the hiss can be somewhat audible. They can also make some strange noises if they're not firmly bedded in the saddle, but that's easily fixable. They have their advantages.
magnet wire price EtLa Pickup Makers 27 11-20-2006 08:37 PM
Flexible 28 gauge wire? ken Pickup Makers 0 08-08-2006 03:21 AM
shielded wire? 496dart Build Your Amp 5 07-18-2006 11:49 PM
