Go Back   Music Electronics Forum > Amplification > Guitar Amps > Vintage Amps > Repair and Restoration
Old 11-06-2007, 10:37 PM   #1
Plexi, is it safe to power up?
I've just taken delivery of a 40 year old Marshall JPM50 Plexi, which has lay in someone's attic for twenty years unused. Every thing looks ok, when I turn the power switch on with an ohmmeter across the power cord I get a resistance measurement of 12.5 Ohms.
I would be grateful for comments on the following:-
With that resitance reading will it be safe to connect to a power supply and switch on.
Any tips on how I should approach power up as this thing has been idle for so long.
Regards and Thanks
Manilito
Manalito is offline   Reply With Quote
Old 11-06-2007, 11:52 PM   #2
It is best to power it up thru a variac or a current limiter first,to "re-form" the caps.IME an amp that has sat that long without being powered up needs to be re-capped anyway,so you may want to skip the "safe" power up and go right to a re-cap.
stokes is offline   Reply With Quote
Old 01-10-2008, 01:36 AM   #3
i second that.....re cap it, then bring it up with a variac, slowly, so you have a chance to see if anything has gone wrong before you reach the danger zone! :-)
deluxe reverb92 is offline   Reply With Quote
15w Alnico Blue [safe w/15w ?] petemoore 5 E 3 9 03-02-2008 05:18 PM
Alnico Blue..Safe in my Vintage 5E3 Gibby 5 E 3 14 02-04-2008 03:22 AM
Installing a Bigsby vibrato arm myself. Safe? Smart? Wiborg Guitar Tech 3 09-18-2007 02:33 AM
When is it safe to work on? ajs Maintenance, Troubleshooting & Repair 1 07-16-2007 01:27 AM
Plexi JC@ Vintage Amps 11 06-16-2006 12:21 AM
