Go Back   Music Electronics Forum > Amplification > Guitar Amps > Theory & Design
Old 08-14-2006, 11:40 PM   #1
scole's Avatar
champ/princeton alternatives
id like to build a princeton (champ with tone control) im wondering if there are any improved versions? other than the fender tweed or blackface designs.
scole is offline   Reply With Quote
Old 08-22-2006, 12:06 PM   #2
Lifetime Member
Rob Mercure's Avatar
Define the "improvements" you seek! Lotsa playing around room with these simple designs so small circuit changes often make lotsa difference.
Rob
Rob Mercure is offline   Reply With Quote
Old 08-22-2006, 05:09 PM   #3
Senior Hollow State Tech
Bruce / Mission Amps's Avatar
Scott the biggest improvements I've heard are when a builder uses a "real", higher end 10 watt OT, a larger cabinet, (like one from a Harvard), and a great speaker.
Bruce
__________________
Bruce
Mission Amps
Denver, CO. 80022
www.missionamps.com
303-955-2412
Bruce / Mission Amps is offline   Reply With Quote
Old 08-22-2006, 08:52 PM   #4
Just to add to Bruces reply,try a 6L6 type power tube.I have a tweed clone with a 7591 power tube and switchable between cathode and fixed bias,and an Amperex 5AR4 rect.It is in a fairly large cab made out of maple with a 10 inch Weber speaker,puts out 12 clean watts and maxes at about 17watts.The Weber speaker was the last change and really took it over the edge.
stokes is offline   Reply With Quote
Princeton help 496dart Maintenance, Troubleshooting & Repair 28 05-23-2008 01:59 AM
72 Princeton overhaul? sgmarshall Mods & Tweeks 2 08-09-2006 03:30 AM
'speaker out' mod for Super Champ Analog Assassin Guitar Amps 2 07-23-2006 07:34 PM
SF Vibro Champ Ex Cond tuberattler Flea Market 0 06-16-2006 05:05 AM
PT current rating for 6L6 in Brown Princeton pete_b Tweed Builders 2 06-13-2006 09:31 PM
