Assuming all the taps have a common (-) wire, go right ahead and do that.
If you have to do things with multiple wires to select an output impedance, it gets a little more complicated - in that case, I would tap the NFB from the 8-ohm (or whatever you're gonna use) tap and (be prepared to) scale the resistors that feed it to the PI.
Hope this helps!
LinkBack URL
About LinkBacks
