Originally Posted by
petemoore
That or maybe I need a 'trust-o-meter' for my trusty / cheepo 'ol 4 bukk DMM?
The Vox PT, pulled, with 120AC going to primary, 'measures' 802VAC across the secondary, with center tap..near center, the MM sitting next to it on the bench [w/same input V] showed 847VAC secondary output [on DMM].
...according to this silly meter, [I should stick it in the wall plug for AC scale reference],[I didn't actually measure the primary supply... now thinking...re-thinking..] to see if it says 120 or so VAC there.
Re-armed with the RCA Tube Manual...and better understanding of PP and SE topology [much thanks to MJWB !], I return to the gathering of info from reference data and various PP/SE schemata of AC / 5e3 and so on.
