| | #1 |
| Member Join Date: Mar 2007
| Rectifier with over rated filter cap, what will happen?
Hey, Just built a 5E3 and I'm using an EZ81 has the rectifier right now, but I also have some 6AX5GT 8-pin rectifiers, tung sol, GE and an RCA one, I'm using a 22uF 450 volt as my first filter cap but the data sheet for the 6AX5GT says 10uF max is it worth trying it or will it just burn out? what will happen has anybody else tried something similar? Would also like to stop using my frankenstien 8-9 pin adapter! the reason all this started is because my PT only has a 6.3v winding it is rated over 4amps so shouldn't be a problem was running 9 valves before. thanks! |
| | #2 |
| Senior Member Join Date: Nov 2007 Location: Springdale, Arkansas
I would go with the octal tube and the 22uf cap will be ok, but maybe use a 500 volt rating depending on where your B+ ends up.
| | #3 |
at the moment I get 374v B+ at the first filter cap with an EZ81 so I'll give the 6ax5gt's a go and keep an eye on them. its always fun to experiment
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Limiting max filter capacitance on 1st stage of Bass amp B+, or Pi filter? | satsloader | Theory & Design | 13 | 10-16-2007 02:20 AM |
| Bridge rectifier vs. two-diode rectifier????????? | anson | Theory & Design | 3 | 08-11-2007 11:03 PM |
| Highpass filter...? | SteikBacon | Pickup Makers | 5 | 07-07-2007 01:01 AM |
| Filter cap voltage | grandmasterflash213 | Maintenance, Troubleshooting & Repair | 2 | 04-18-2007 07:03 PM |
| 5F1 Rectifier | fabiomayo | Tweed Builders | 12 | 10-12-2006 08:05 PM |
