Go Back   Music Electronics Forum > Amplification > Guitar Amps > Vintage Amps
Old 11-21-2007, 08:17 PM   #1
oxford speakers
Hey there, I´m considering buying an old silverface vibrolux but I´m not particularly happy with the speakers (oxford 10L5). Does anybody has good experiences with (new) eminence speakers raging cajun or ramrod ? other suggestions ? by the way, what´s the weight of these old oxfords ? (i wanna know if the amp will be heavier after changing speakers - weight´s an issue...); thanks, ross
rosstiger is offline   Reply With Quote
Old 11-26-2007, 07:02 AM   #2
I've used Eminence Legend 105 10 inch speakers in a 2x10 and they sound very nice and aren't too expensive either. Certainly better than older Oxfarts.
Greg
soundmasterg is offline   Reply With Quote
Old 11-26-2007, 09:06 PM   #3
oxfarts
yeah - that´s how they sound these oxfords... the legend is not too dark ? I narrowed it down to either legends or copperheads now. i´m using a strat and like a tight funky clean sound and overdrive sounds a la stevie ray...thanks
Old 11-26-2007, 10:28 PM   #4
TD_Madden's Avatar
In my SF Vibrolux reverb I use a Weber C10Q (think it's a 10F150) and a CopperHead....nice and spanky.
TD_Madden is offline   Reply With Quote
Old 11-27-2007, 02:19 AM   #5
Weber has some great speakers,if you email him and tell him what you are looking to achieve he will give you some top flight advice.
stokes is offline   Reply With Quote
Old 11-27-2007, 09:56 PM   #6
bargoedboy's Avatar
i put a 12" eminence red coat Tonka in my vibrolux , totally transformed the amp ! mine had the oxfords which i thought was poor , i`m not a big fan of the alnico jensen speakers yet they do some ceramics which sound great .
bargoedboy is offline   Reply With Quote
Old 11-27-2007, 10:12 PM   #7
TD_Madden's Avatar
You know that the VR expects a 4-ohm load, right? The Tonker is 8 ohms, I think.
Old 11-28-2007, 06:49 AM   #8
bargoedboy's Avatar
Thumbs up
yes i know the ohmage is wrong but the tone was so good, if the vibrolux was an 8ohm load and the tonka a 4ohm then i wouldn`t even attempt it, but the concensus of opinion is that it will take the 8ohm speaker with no problem. thanks for pointing it out , i should have done that but forgot.
Old 11-28-2007, 02:39 PM   #9
TD_Madden's Avatar
Supposedly the older Fender's were robust enough to handle a mismatch either way....and you're right, you can get some great tones doing this.
Old 12-27-2007, 04:06 PM   #10
Wink P's & Q's
Quote:
In old Jensen speak :
R = 1" vc
Q = 1.25" vc http://taweber.powweb.com/weber/10f125.htm
N = 1.5" vc
A 10F150 is a C10N
JJ
Jammin'John is offline   Reply With Quote
Mounting speakers Bernardduur Cabinetry 4 12-15-2007 12:23 PM
Neodymium speakers Ptron Guitar Amps 8 11-14-2007 01:14 AM
Anyone help me ID these speakers? Steve Conner Guitar Amps 1 10-02-2007 08:42 PM
speakers stratman1188 Build Your Amp 3 07-31-2007 04:21 PM
looking for input on 5e7 speakers john t Tweed Builders 3 10-01-2006 05:01 PM
