Here's the measurements of the bobbin taken with a digital caliper:
The top flatwork is 0.602" (15.31mm) by 2.626" (66.72mm). 0.060" (1.55mm) thick.
The bottom is 0.90" (22.86mm) at the thickest part, by 3.286" (83.49mm) long. 0.123" (3.13mm) thick.
0.403" (10.25mm) between top and bottom flatwork.
Magnets are 0.185" diameter, and are 2.04" from E to E (centers). 2.225 to the outsides of the magnets.
They are 0.628 tall. They slightly protrude from the top flatwork by 0.035" (0.90mm).
On mine the top is black and the bottom is gray. It has a blue and yellow wire. The mounting holes are 3.04" apart.
LinkBack URL
About LinkBacks
Quick question.. 0.628 tall, are you referring to the magnet length or top of flatwork? Also, by the pics I assume they're wound fairly light
It gives a light and airy tone... kind of like an air coil!
