| | #1 |
| Tone Mechanic Join Date: Dec 2006
| Determining a short with an LCR meter
Besides identifying unusally low DCR in a coil, what other way(s) can you tell that you have a short in a coil using an LCR meter? Does it have something to do with the AC? |
| | #2 |
| Senior Member Join Date: Mar 2007 Location: Philadelphia suburbs
It has everyting to do with the AC! That is what the 'L' (inductance) part of the meter is using to measure the coil. It usually will measure the inductance at 1kHz. If you have a shorted turn, the inductance will be unusually low. Of course, like DCR, this is only valuable if you know what it is supposed to measure in the first place. Why do you think you have a short? Do you have any other coils like it that you can measure? There are calculations for both inductance & dcr that you can do to determine what the resistance & inductance is supposed to be for any given configuration. Do you know how many feet of wire were wound onto the coil? Knowing that and the ohms / ft of the wire gauge will tell you what the DCR should be. The inductance calculations are way more involved. You can Google "calculate coil inductance" (or something similar) and find the info you need to calculate it out. Chris |
| | #3 |
| Old Timer Join Date: May 2006 Location: The Dog House
If you have a short the DC reading will wander. A sure sign.
| | #4 |
| Old Timer Join Date: May 2006 Location: Boston, MA area
| The most sensitive approach using the Extech LCR meter is to measure inductance and AC resistance at 1 KHz. A short will cause the AC resistance to be much higher than usual. This works even if the DC resistance change is too small to be detected.
| | #5 | |
| Quote:
Could you give an example. Sort of walk through a scenerio so that we can get an idea of what to look for....I'm by no means an electrical engineer here Let's say i have a bobbin that reads 4k Ohm DCR. What would the inductance and ACR readings normally be (ball park of course) and what would they read if there was a slight short? Or if you have a better example, please provide. Last edited by kevinT; 12-02-2007 at 07:19 PM. | |
| | #6 | |
| Quote:
What I call "excess" AC resistance (being the difference between AC and DC resistances, the AC resistance always being the larger of the two) is proportional to the eddy current loading on the coil being tested In an air coil well away from any metal, AC and DC resistances are equal or almost so. If you bring a piece of metal near, the AC resistance will rise while the DC resistance stays the same. The excess (ACr-DCr) represents the energy lost to eddy-current heating of the metal. With a sufficiently powerful AC signal, the metal will become hot to the touch. This is used industrially, and is called "induction heating" (http://en.wikipedia.org/wiki/Induction_heating and http://www.ameritherm.com/aboutinduction.php). Back to pickups. It's pretty much impossible to compute what the AC resistance of a variable-reluctance sensor like a guitar pickup ought to be from first principles, unless one uses one of the very large and expensive software tools designed for the purpose (http://www.ansoft.com/device/sensor/...duct=simplorer), so in the pickup world one does it by comparison. Measure the inductance, Rdc and Rac of every pickup you make. Be very suspicious of any unit (by serial number) whose excess resistance is out of line with other units of the same model. | |
| | #7 | |
| Pickup Maker Join Date: May 2006 Location: Montclair, NJ
| Quote:
That was a great post Joe. Now I have to get one of those Extech LCR meters.
__________________ Those who create are rare; those who cannot are numerous. Therefore, the latter are stronger. - Coco Chanel www.sgd-lutherie.com www.myspace.com/sgdlutherie www.myspace.com/davidschwab | |
| | #8 |
| Old Timer Join Date: May 2006 Location: Planet Mongo in the country of PAF
| Extech
They've been discontinued but you might still find some... 45 heavy, I hear you can get 90K on a strat coil, that ought to sound like, uh, 90K |
| | #9 | |
| Quote:
| | #10 | |
| Yeah, I saw someone mention that here. Are there any other brands that work with pickups? Quote:
I've been winding high inductance/low resistance pickups, so I'm curious how this would figure into the equation, since it will be higher resistance, and lower inductance. I think a little would go a long way.... I'm just getting around to trying out different windings and stuff. I wound two identical pickups, one with 3K turns per coil, and one with 4K turns, 42 on each. Besides the obvious output difference, which I expected, the hotter pickup actually sounds brighter in the bridge position! This is on a bass. I think it has a lower resonant peak which is accentuating the highs. The other pickup sounds much flatter and more middly. I'm trying to get the lower one brighter. (the customer wanted a bassy neck and bright bridge pickup for his bass... which is the opposite way that I usually make them.) Boy, you could spend all day doing this stuff...
| | #11 |
| skinny wire...
Yeah I just snagged 13 lbs of single build formvar 44 gauge myself, I was running out of the poly stuff and got sort of a deal on it, will probably last forever. Let us know how that wire turns out. Haven't wound much with the formvar to know if its much different yet....
| | #12 |
| Member Join Date: Apr 2007
A good alternative to the Extech type meter is an old impedance bridge. Much larger physically, but no no worries about whether it will measure pickups correctly, which is an issue with the digital ones (discussed at length here) They go way cheap on ebay, good ones are ESI 250 DA (what I use) and ESI 250 DE and the General Radio 1650s, and there are other good ones too. Here is a refurb for $100 BIN that has been checked out by a tech http://cgi.ebay.com/Crescent-ZM-30-U...QQcmdZViewItem |
| | #13 |
Wow... that thing would sure make you look like a mad scientist!
| | #14 | |
| Re: Skinny Wire Quote:
Whatever feel I learned working with 43 is useless! I broke a lot of wire starting out. Then it got easier. 3000 turns gave me 5.33K... 4000 turns gave me a 7K coil! I wont get to hear it until tomorrow... Oh, the suspense.
| | #15 |
cool. can't wait to hear the results david.
| | #16 |
| Here's the pickup, in series and parallel, and buffered. Excuse the sloppy playing... The guy wanted a very bright pickup ... I think this is pretty bright! Series (12.17K) Parallel (6.08K) (David King... look, high Z pickups! I wound the two coils differently (as stated in my previous post). It uses two neo magnets.
| | #17 | |
| Quote:
Sounds good david. You can definitely hear the difference between the two. I think i like the lower output one in parallel. clearer more defined. The higher output one is a little grittier. | |
| | #18 | |
| Quote:
Neos really have a growl to them. I wouldn't be surprised if the steel cores are getting saturated. I can actually stick the pickup, out of it's case, onto my refrigerator door, and pull it open! Doesn't seem to affect the vibration of the bass strings though. Unless you get really close. I like this a little better... This was the original bridge pickup But he wanted it brighter. The same pickup, would a little hotter was used for the neck. (I wind my bridge hotter, but that's not what he wanted) This is the neck pickup And for yet another tone, here's the neck pickup from the set at the bridge location. It's amazing what a slightly different number of turns will do. I had a lot of fun doing this project. Gave me an excuse to rewind the pickup a few times.
| | #19 |
| Where did you hear that the Extech 380193 LCR meter was discontinued? I just called Extech and asked. Their reaction was mystification, and they said that there are plenty of units in the supply pipeline. For instance, Test Instrument Depot (who I have bought stuff from) has them: http://www.testequipmentdepot.com/ex...ers/380193.htm. |
| | #20 |
I'm pretty sure it was on their website, if not it was on a commercial shopping site, that was probably 7 months ago and probably a test instrument website, it wasn't a rumor thing.
| | #21 | |
| Quote:
I have had salesmen tell me that whatever I had asked for was no longer made, the intent being to steer me to whatever the salesman happened to be selling. | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Can A Broken LED Short FX? | dumbassbob | Guitar Effects | 5 | 07-24-2007 08:13 PM |
| Determining current capacity of a htr winding | studioit | Theory & Design | 3 | 02-17-2007 09:20 PM |
| Determining Size of Choke | chunkitup | Theory & Design | 4 | 02-05-2007 04:23 AM |
| Short? | mick | Pickup Makers | 10 | 11-11-2006 01:13 AM |
| Anybody try the TAD short bottle 6L6's? | Regis | Tubes (Valves) | 15 | 07-25-2006 02:30 AM |
