Results 1 to 5 of 5
Thread: Peavey Valveking 112
    Feb 2007
    25
    I have this peavey valveking that sounds weak and distorted. I've replaced the preamp tubes, phase inverter tube, power tubes, and check for opened resistors. I didn't find anything. I've noticed a defective 4560 IC and replaced it, but it didn't resolve the issue. What could be causing this?
    Senior Member Enzo's Avatar
    Lansing, Michigan, USA
    18,042
    Isolate the problem, is it the power amp or the preamp that is bad?
    Apply a signal to the input and trace it through the amp, find out where it doesn't make the jumpe from stage to stage.
    Feb 2007
    25
    It looks like it's in both. There's distortion coming out the main speaker and distortion on the preamp: going from the send on the effects loop to the input jack of another amp.
    18,042
    Well, if the distortion is present at the preamp out, it won't disappear going to the power amp. APply a clean test signal from somewhere else to the power amp input.
    As to the preamp, as I said, apply a clean signal at the input and trace it through stage by stage.
    Feb 2007
    25
    Thanks! I'll give it a shot.
  1. Peavey Valveking 112 Mod ?
    By msclford in forum Mods & Tweeks
    Last Post: 09-18-2008, 02:07 AM
  2. valveking 112
    By JC@ in forum Mods & Tweeks
    Last Post: 05-03-2007, 01:03 PM
  3. Weird noise on Peavey Valveking head
    By tenrousei in forum Maintenance, Troubleshooting & Repair
    Last Post: 01-09-2007, 02:08 AM
