Go Back   Music Electronics Forum > Amplification > Guitar Amps > Theory & Design
Old 12-25-2007, 05:15 PM   #1
Removing Rivets?
What is the best method for removing steel riverts? I can get them out, but sometimes they spin and are difficult to remove.
tbryanh is offline   Reply With Quote
Old 12-25-2007, 05:34 PM   #2
Joey Voltage's Avatar
I usually just drill them out, but if you are talking about riv-nuts, they are a little tricky...maybe bolt cutters.
Joey Voltage is offline   Reply With Quote
Old 12-26-2007, 09:37 AM   #3
Supporting Member
Alex R's Avatar
If they spin when you're drilling them try a centrepunch on one edge to hold them in place. But generally I just get fierce and drill at an angle.
Alex R is offline   Reply With Quote
Old 12-27-2007, 05:56 AM   #4
I angle the drill on spinners, so the side of the drill is eating into the rivet as the thing turns.
If one refuses to cooperate, I can always grind the thing off with my Dremel. Worried about the finish? Do it underneath.
removing 2 pwr tubes in a 4 tube amp Mars Amp Repair Maintenance, Troubleshooting & Repair 4 03-14-2007 02:32 AM
removing hairline scratches from bobbins kevinT Pickup Makers 6 01-13-2007 08:16 AM
