Results 1 to 3 of 3
Thread: Help me care for of my 72 Fender Twin Reverb
    May 2007
    16
    I have a silver face Twin reverb that looks completely stock. What is the best way to keep this baby in nice shape? Any preventative maintenance should be performed? As far as the output tubes go three of them are Sylvania and one is RCA. I'm sure there is a matching issue. The power of the amp does seem a bit low. I've already replaced the pre amp tubes with Telefunken 12Ax7's because the 7025's were spent. I am a little confused about the different schematics I've seen of this amp. What is the difference between AB763, AA769, AA270, AA764 schematics? How do I know which I have?
    May 2007
    16
    Also when I look at the circuit board I see the following electrolytics.
    (5) 25MFD 25V
    (2) 50MFD 70V
    (1) 5MFD 50V
    On most schematics I've seen there is what appears to be a multi can cap (B, C D) with 20MFD 525V and (2) 70MFD 350V caps. I don't see these. Shouldn't they be very obvious?
    Senior Member Twist's Avatar
    Nov 2007
    Springdale, Arkansas
    314
    There is no multisection cap on that amp. Under the amp chassis is a rectangular cover and under that are some electrolytics. Unplug the amp to give the caps time to discharge then look at those filter caps. If they look original I would recommend taking it to a tech and having them replaced. You'll be surprised at the results. Also have someone install a matched quartet of output tubes. An experienced tech will know other common problems to address like cold solder joints and dirty pots.
  1. Fender Twin Reverb, too bright?
    By shiner555 in forum Mods & Tweeks
    Last Post: 12-13-2007, 04:54 PM
  2. Fender Twin Reverb II static??
    By chrisxx in forum Maintenance, Troubleshooting & Repair
    Last Post: 08-17-2007, 02:19 PM
  3. Fender PA 100 to Twin Reverb convertion
    By bluesmojo in forum Theory & Design
    Last Post: 08-12-2007, 09:34 PM
  4. Fender Twin Reverb
    By Dano in forum Music Electronics
    Last Post: 10-23-2006, 10:56 PM
  5. Slight problem with my Fender Twin Reverb.
    By Humbucker in forum Vintage Amps
    Last Post: 06-13-2006, 02:03 AM
