Did the amp sound fine before and if so how long did you have the amp. Regardless of the confusion on the mains voltage something has shorted in the amp. I would first take out the output tubes and replace the fuse and power up. If it powers up then you need to take some readings from the pins in the output tube sockets. This should tell you if you have an import tranny. Newer Marshalls can be rewired for domestic use.
LinkBack URL
About LinkBacks
