Go Back   Music Electronics Forum > Amplification > Guitar Amps > Vintage Amps > Repair and Restoration
Old 12-28-2007, 08:22 PM   #1
Fender Twin master volume pot
Hi,
I am working on a Fender Twin Reverb(silver face) and I have not been able (so far) to find a replacement for the master volume pot/push-pull DPST switch. Any idea of a supplier selling this?Preferably in Europe
Cheers
Mauri
Maurizio is offline   Reply With Quote
Old 12-29-2007, 01:54 AM   #2
Supporting Member
Alex R's Avatar
They are hard to get hold of... not much room under that slant faceplate, and the actual type is I think no longer made. However it is possible to take out the overdrive circuit altogether. Are you sure you want it - it sounds horrible! Here's one in Germany anyhow:
http://www.tubeampdoctor.com/product...products_id=29
Alex R is offline   Reply With Quote
Old 12-29-2007, 11:46 AM   #3
yes, it doesn't sound good at all. but the amp is not mine so I'll have to ask permission to the owner before removing it. Thanks for the link!
Old 12-30-2007, 02:47 AM   #4
Antique Electronic Supply has several pots that would work. You'll have to poke around the site a bit. Check closeouts, too. A fairly useful mod for the MV Twins is to dump the useless boost function, and move the master volume post phase-inverter.
http://www.tubesandmore.com/scripts/...item=R-VPP-1MA
Sweetfinger is offline   Reply With Quote
Old 02-03-2008, 10:35 AM   #5
I wouldn't mind a few hints if somebody knows how to remove the master volume section
lordnielson is offline   Reply With Quote
Old 02-03-2008, 01:56 PM   #6
You can find these pots at Watford Valves in the UK
http://www.watfordvalves.com/product_detail.asp?id=530
I've bought one and can confirm it's the exact same as the original. A friend has this amp and loves the pull boost. When the switch disintegrated I couldn't convince him he would be better without it.
Weber has pull switch pots but these are too big and don't fit into the fender chassis.
To remove the master vol just turn it up to 10 - voila, it's out of the circuit.
Sorry if this info is too late for that job.
Peter
pdf64 is offline   Reply With Quote
Old 12-19-2008, 06:55 PM   #7
I also wanted to move the MV post phase inverter, what would the wiring be? Also if you wanted to take it out, how would you solder the jumper? does there need to be a resistor in place of the MV pot?
darrellcheng is offline   Reply With Quote
master volume for 5E3 k51502 Guitar Amps 4 12-06-2007 04:38 PM
5e3 master volume??? playafndr 5 E 3 5 10-24-2007 06:32 PM
Twin reverb SF master volume JC@ Vintage Amps 2 04-13-2007 07:53 PM
Ampeg master volume footswitch walkman Vintage Amps 12 04-08-2007 02:08 AM
Master Volume twin Reverb Krong Vintage Amps 5 10-31-2006 05:47 AM
