| | #1 |
| Junior Member Join Date: Dec 2007
| Help, please. Orange Tiny Terror problem.
Hi people I'd like some help, some words of wisdom from you. Now, I have this Orange Tiny Terror. Each timy I switch standby on/off I hear this noise, which seems to go away after few seconds. The actual volume of the noise depends on (ta-daaam) where the amp's volume knob is set (And if the volume knob is zeroed there's no noise). Now, I use to always zero the gain and volume knobs before doing any standby/switching, so I never noticed there's a problem until recently. What can be the cause? What should I do? There also were few times the amp lost so volume and started to sound unpleasant and too distorted, or developed noise on top of the signal while I was playing. But I figured it was caused by cab vibrations. So, not putting the head on the cab solved that problem (for now). Please, please help Thanks V. |
| | #2 |
| Senior Member Join Date: Sep 2006 Location: Englewood, CO
Well I'm not familiar with that particular Orange amp. There are other posts on this forum from about feb 2007...seems like this is a very interesting design....You could also visit the Orange forum. http://www.orangeamps.com glen
| | #3 |
| Senior Member Join Date: Jul 2006 Location: Baton Rouge,LA
I would check your tubes as those symtoms apply to that. When you hit the standby switch and the volume is cranked it's going to hit the grids of the power tubes harder with initial inrush current than settle down to it's nominal instantaneous operating current. If you don't want to hear it keep it down but I don't personally think there is a problem. btw I have worked and tested on several of these and they are pretty cool but one trick ponies without mods.
__________________ KB |
| | #4 |
Thanks guys. Amp Kat, I'm cool with that one trick, thank you Bot, I tried few sets of JJ EL's, and changed the preamp tubes also, it doesn't help. Some say it might be: 1) voltage arcing on plastic sockets 2) signal coupling resistor I just have no guts to open it and change the sockets, because there's no amp tech around and i'd have to solder by myself, which I do terribly. I'd be glad to know other options and opinions on that problem (if there's any problem at all |
| | #5 |
Yes, I like the sound of the little terror and they are quite impressive for such a little box. I'll try the one at the shop and see if it does it too. Some of the symptoms that would cause it as you said are :faulty sockets,bad switch,bad filter cap,bad or loose connection.
| | #6 |
| Member Join Date: Oct 2006 Location: CT - USA
| One option...
You have to open it up, but need not know any more than to wear tennis shoes, keep one arm behind your back and poke at wires with a wooden chopstick. I've found numerous bad sockets this way (have one right now, as a matter of fact). Even if you're not going to fix it yourself, it might be a super simple way of diagnosis. Just be careful..... one arm behind the back or under your butt while poking. Last edited by captntasty; 01-02-2008 at 07:32 PM. Reason: spelllling |
| | #7 |
| Senior Member Join Date: Jun 2006
Here's a late model Orange amp I fixed last year I think.....not a tiny terror......but beware this isn't pretty, don't look if you have a weak stomach! http://smg.photobucket.com/albums/v3...t=100_1918.jpg |
| | #8 | ||
| Quote:
Quote:
Oh, why did I look! Thanks a lot! | ||
| | #9 |
Um... it makes a noise for a brief period when first turned on? So does my wife. Other than that you don't know why it is there, what is the problem? Lots of amps make wake up noises. it is not arcing sockets or it would continue to do it. COld tubes warming up often make noises. I just don't see any of that as a problem. Hell, I make noises when I wake up. let it warm up a minute before playing, leave the volume down. Noises don't usually hurt the amp.
| | #10 |
Enzo, it isn't supposed to make those noises - according to youtube demos |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Anyone know what the "tiny terror" circuit is? | FatGaz | Guitar Amps | 194 | 03-04-2010 02:36 PM |
| Clean-dirty on orange tiny terror | bmxbandit | Maintenance, Troubleshooting & Repair | 7 | 07-26-2009 12:09 AM |
| Designing 35W Tiny Terror w/clean channel | tonejones | Theory & Design | 7 | 12-25-2008 07:51 AM |
| Orange Tiny Terror B+? | Shark_Sandwich | Theory & Design | 1 | 05-31-2008 10:54 PM |
| Peavey Valve King Royal 8 / Orange Tiny Terror head | Steve A. | Guitar Amps | 8 | 06-25-2007 09:36 PM |
