Go Back   Music Electronics Forum > Amplification > Guitar Amps > Mods & Tweeks
Old 12-31-2007, 08:30 AM   #1
6CG7 swap for EL84 ?
Having never tried swapping tube types, I'm hesitant to try it.
EL84:
ftp://ftp.eierc.com/pub/rc/Ei-EL84.pdf
6CG7:
http://www.triodeel.com/6cg7_p1.gif
Heaters, inputs/outputs, and pin 9 being internal shield look compatible, these tube types look similar in many ways.
18w clone W/342v on the plates.
Do you think I should just drop in the 6CG7's and test them or am I missing something first ?
petemoore is offline   Reply With Quote
Old 12-31-2007, 04:37 PM   #2
Supporting Member
Alex R's Avatar
No, the 6CG7 is a twin triode, wired more like a 12AX7 and not at all like an EL84.
Alex R is offline   Reply With Quote
Tube swap on Hiwatt davoux Maintenance, Troubleshooting & Repair 11 07-25-2008 02:49 PM
Valve Jnr EL84 bias.. grandmasterflash213 Maintenance, Troubleshooting & Repair 3 05-27-2007 04:24 PM
EL84 power amp design zikaj Theory & Design 2 05-18-2007 03:07 PM
Pickup swap guitar Paulkstadden Pickup Makers 23 02-21-2007 09:26 PM
wich four el84? scole Build Your Amp 0 11-25-2006 03:58 PM
