Results 1 to 12 of 12
Thread: Secondary's C.T. tied to Totem Pole Caps???
    Nov 2006
    North America
    22
    Hi Folks!
    I was just curious as to why the center tap of the mains transformer secondaries are tied to the junction of the power supply's (totem pole config'd) first stage filter capacitors? Does this effectively create a voltage doubler arrangement? With the FWB rectification scheme, I would think that one could float the C.T. entirely. TIA!
    Oh, here's some schematics that illustrate what I am talking about, they are all pdf's. The Orange schematics are the more simple ones (2nd & 3rd):
    http://www.schematicheaven.com/marsh...100w_2203u.pdf
    http://www.schematicheaven.com/newam...e_mkii1973.pdf
    http://www.schematicheaven.com/newam...e_mkii1972.pdf
    http://www.schematicheaven.com/newam...ek_mig100h.pdf
    Senior Member Old Tele man's Avatar
    Oct 2007
    Tucson, AZ
    473
    ...it's a voltage doubler circuit
    Supporting Member loudthud's Avatar
    Near Dallas Texas
    2,151
    The circuits you linked are not voltage doublers. The center tap connection is just used to insure equal voltage across the two filter caps that are in series. It's the same configuration that you see in solid state power amps with bipolar supplies except that the minus supply is grounded.
    Oct 2007
    Tucson, AZ
    473
    Quote Originally Posted by loudthud View Post
    ...I stand corrected, so it's just a "hard-wired" voltage balance point. Obviously, I didn't look hard enough at the schematic.
    Nov 2006
    North America
    22
    Thank you VERY much guys! If I may pry just a tad more about this connection:
    Is it the 'balance' of the secondary windings that does this? I'm trying to visualize how this functions... TIA!
    HAPPY NEW YEAR!
    Oct 2007
    Tucson, AZ
    473
    ...I did a little "homework" and textbook "researching" and it's actually a 'voltage-stacking' re-configuration of the normal "Dual Complementry" rectifier circuit (Linear Magnetics App Note):
    ...the re-configuration from "dual ± voltages" to 'voltage-stacking' is accomplished by simply moving the "ground" from between the two capacitors (and xfmr center-tap) over to the 'negative-side' of the two stacked capacitors; however, the final 'stacked' voltage is same as from normal BRIDGE ckt, so it's not a voltage-doubler.
    ...and, the xfmr-winding acts as the voltage-balancer for the two caps (taking the place of the 220K voltage-balancing resisitors typically used on stacked capacitors).
  7. #7
    Lifetime Member
    Nov 2007
    42
    Umm...that's still not the Marshall connection. What you've got is a pretty standard split load supply. The Marshall version still grounds the anode side of the rectifier allowing only a single positive supply. You get two advantages here. First, a "standard" center tap transformer can be used with a bridge rectifier without fouling things up and the second advantage is that, as loud thud already stated, you've got an equal voltage across both capacitors.
    Cornell Dublier used to have a rather large white paper on their site explaining all the pros and cons of several different capacitor connection arrangements. Don't know if it's still up or not as the site as undergone a massive overhaul since I was there last.
    -Carl
  8. #8
    Oct 2007
    Tucson, AZ
    473
    ...the pix is of a "dual complementary" circuit, not the "voltage-stack" arrangement, it's just to illustrate where & how the "stack" arrangement is derived from.
  9. #9
    Lifetime Member
    Nov 2007
    42
    Ok, found the app note. Very informatie read!
    http://www.cde.com/catalogs/AEappGUIDE.pdf
    -Carl
  10. #10
    Jul 2007
    100
    I PSpiced the 1st link that Tobacco posted, and it's a doubler.....
  11. #11
    Oct 2007
    Tucson, AZ
    473
    Quote Originally Posted by Earl View Post
    ...but did that assume PT-voltage was 'end-to-end' or PT-voltage was 'end-to-centertap'?
  12. #12
    Jul 2007
    100
    OTM - I just used 2. 1V peak SIN sources in series, and CT'd the junction of the two.
    I guess, in 'normal' terms, that would be a 0.7 - 0 - 0.7 VRMS output..?
  1. Interesting way to insulate your pole screws...
    By David Schwab in forum Pickup Makers
    Last Post: 01-10-2008, 12:01 AM
  2. Tied off lead wires?
    By Dr. Guitar in forum Pickup Makers
    Last Post: 12-07-2007, 05:05 AM
  3. Gold Pole Pieces
    By dayvo in forum Pickup Makers
    Last Post: 06-26-2007, 11:56 AM
  4. Inductance w/wo pole pieces
    By KT66 in forum Pickup Makers
    Last Post: 03-26-2007, 07:52 AM
  5. pole lenght
    By Marco Pancaldi in forum Pickup Makers
    Last Post: 01-29-2007, 08:33 AM
