| Guitar Amps General discussion about amps |
| | #1 |
| Junior Member Join Date: Jan 2008
| JCM800 50 watt lead series/bias adjust
Hi, please forgive my ignorance. I want to change tubes on my amp. There are two 6550`s and three 12ax7`s. I want to Re Bias...Where do I put the probes of my meter and what are my bias numbers?...I really need my hand held on this one Thanks.....
| | #2 |
| Senior Member Join Date: May 2007 Location: SW Florida
I recommend reading a good article before adjusting bias. The simplest method is to put in 1 ohm resistors and measure to the cathode voltage of each tube. The current depends on the plate voltage of your amp. Here's a fantastic page for bias settings http://www.webervst.com/tubes/calcbias.htm
__________________ See the birth of a 2-watt tube guitar amp - the "Dyno Tweed" http://www.naturdoctor.com/Chapters/Amps/DynoTweed.html |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Marshall JCM 800 Lead Series - 100 Watt - Blowing 1 amp fuse when turning on Standby | cogorman | Maintenance, Troubleshooting & Repair | 6 | 12-13-2007 04:30 AM |
| Marshall 50 watt JCM800 PT\Heyboer Woes | tork | Maintenance, Troubleshooting & Repair | 7 | 06-15-2007 12:09 AM |
| ashdown peacemaker 60 bias adjust | Mars Amp Repair | Maintenance, Troubleshooting & Repair | 3 | 05-25-2007 03:43 PM |
| Hiwatt Lead 50 bias reistor | tonezoneonline | Maintenance, Troubleshooting & Repair | 7 | 04-25-2007 04:08 PM |
| 40ish watt amp through 30 watt speaker, dangerous? | tunakdude | Theory & Design | 6 | 09-03-2006 05:50 PM |
