| | #1 |
| Senior Member Join Date: Jun 2006
| Output transformer for both SE and PP
In my amp design I have separated everything past the PI : dual bias supplies, cathode resistors and caps, etc. This is mostly to make it easy for me to go from single-ended to push-pull (AB). Up until now I've thought that to go from one configuration to another would require changing the output transformer but now I'm wondering if I couldn't use a push-pull OT for both, and only use half of the OT for single-ended use. Is this possible ? The OT I plan to use for push-pull (Allen TO25) is 7000 to 4/8 ohms and the OT for single-ended (Allen TO11C) is 4000 to 8/16 ohms. Would using only one half of the push-pull still give 4/8 ohms at the secondary ? Or could I use two SE transformers and somehow combine their secondaries ? I suppose I could mount both a SE and a PP OT and switch from one to the other but this would mean switching high voltages (?). Victoria Amps produce an amp that does this sort of thing but it apparently uses a special OT : "The Regal II is designed around a custom bifilar output transformer that is essentially two discrete transformers driving a common speaker load." (see http://www.victoriaamp.com/visitor/show_model/14) Paul P |
| | #2 |
*Ideally* SE OTs require an air gap to avoid DC saturation, in reality using a PP OT for a single ended application will "work". However, for the T025 I'd suggest that you use 1x6L6/5881 power tube (as you're only using half the primary) instead of a 6V6 to restore impedance match). Or try and buy a regal OT from Victoria? |
| | #3 |
| I just got an answer back. Mark says he'll be happy to sell me one for 2800$. He did offer to throw in the rest of the amp at no extra charge... Thanks for the bit about the air gap. Yet one more thing to throw onto the pile of things one should know. Paul P |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Assistance with output transformer in U-45B? | DocGeorge | Vintage Amps | 10 | 09-20-2008 04:15 AM |
| How to tell different ohm taps in an output transformer? | slidincharlie (Carlo P) | Maintenance, Troubleshooting & Repair | 17 | 01-23-2008 01:06 AM |
| Bad Output Transformer | morta | Maintenance, Troubleshooting & Repair | 24 | 01-06-2008 02:56 AM |
| DIY Output Transformer | thomasdj | Build Your Amp | 2 | 12-08-2007 04:41 PM |
| bad output transformer ? | black68 | Repair and Restoration | 3 | 12-20-2006 02:18 PM |
