Go Back   Music Electronics Forum > Effectification > Guitar Effects
Old 01-11-2008, 04:32 PM   #1
Question How do I true bypass vintage effects
Hi everybody I would like to mod three old pedals to true bypass + leds, they are the Dod mini chorus 460, Mxr Dynacomp & Distortion +. I know that I have to replace the original switch with a 3pdt, but after that I dont have a clue as to what wires go where, does any body have a link to some pictures that I can work from or a diy site doing such a mod.
Wobblebelly is offline   Reply With Quote
Old 01-11-2008, 06:35 PM   #2
http://www.diystompboxes.com/wiki/in..._AND_SWITCHING
Just be careful what you wish for. Many classic effects were designed so that the effect volume would be the same as the bypass volume when the impact of the loading was factored in. If you don't know how to recalibrate the bypass volume, you may be causing more grief for yourself.
As well, if the pedal has some decent buffering before it, then TB is not providing anything particularly advantageous, unless you have a tendency to run 4 or 5 classic effects at once, and load the signal down like crazy.
Mark Hammer is offline   Reply With Quote
Old 01-11-2008, 08:08 PM   #3
The easy way is to build an external bypass box. If you want to have a straight-to-the-amp path with all your effects off, you can just have a bypass everything box. If you have vintage effects, they won't be vintage after you true-bypass them.
For most JFET switched pedals, you have to find the effect input/output, not the FET switch input/output, otherwise the effect will always be off.
Otherwise google it, and carve 'em up.
frank.clarke is offline   Reply With Quote
Old 01-11-2008, 08:48 PM   #4
Frank's right.
Please Help Identify this Effects Unit!! Echo Brand Vintage tube tremolo... folkrock75 Guitar Effects 4 12-22-2007 04:22 PM
EH Deluxe Memory Man - True Bypass??? casey73 Guitar Effects 3 07-11-2007 03:26 AM
Vintage Effects / Power craig123 Guitar Effects 9 06-15-2007 10:32 PM
wanna help me figure out how to true-bypass a dean markley overlord? methodofcontrol Guitar Effects 24 03-20-2007 04:03 PM
SmolskiTech True Bypass Loop SmolskiTech Flea Market 4 09-13-2006 10:36 PM
