| | #1 |
| Junior Member Join Date: Dec 2007
| Which power tubes to use?
I'm rebuilding a mid 70's Bassman from the ground up. The tubes all worked when I shut her down last month but I've completely changed the bias section to real bias instead of the Fender "balance" thing. Anyway I was thinking I should get a matched set of tubes. Any suggestions as to manufacturer and/or supplier? How about EL34's? I changed the bias section so I can use either type of tube. I've heard EL34's break up a little sooner and perhaps smoother. Any suggestions? Thanks. |
| | #2 |
| Member Join Date: Aug 2006
| which Tubes
I had John McItyer do a 65 Bassman for me and he put EL-34 in it.he also put both channels togather to cascade gain, only one input.You will go through tubes a little faster,and grid (R) will blow.but they sound great!!!
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Put power tubes in the wrong way!!!Help! | EETStudent | Maintenance, Troubleshooting & Repair | 5 | 01-03-2008 12:15 AM |
| Troubleshooting after power tubes die. | Chill | Maintenance, Troubleshooting & Repair | 17 | 11-23-2007 08:52 PM |
| How to design power supply for tubes? | Realeigo | Theory & Design | 2 | 10-25-2007 12:58 AM |
| Pin 6 on octal power tubes? | Steve Conner | Tubes (Valves) | 1 | 08-18-2007 01:00 AM |
| Power tubes as rectos??? Going mad again :D | Satamax | Theory & Design | 10 | 05-18-2007 01:17 AM |
