| | #1 |
| Junior Member Join Date: Dec 2007
| 70's Princeton - tremelo & tube questions
I have a Princeton "No-Verb". I have two questions: 1. The "vibrato" at minimum speed setting sounds fast. Is one (or half) of the 12AX7 tubes related to the trem circuit, and may have worn down to cause this? Or is the slowest setting on these amps actually fast,and typical of this amp? As you crank the speed,it definitely goes faster,so I don't think it's the pot. The intensity pot works fine. 2. RE Power tubes: I sent back the new 6V6's that I recently got as one is pulling 24 ma and the other 54. I found 2 older 6V6's in my tube collection that are different brands,but are both pulling 30 ma. Is this too hot for this amp,or am I ok,as long as they are both pulling equal current? Much appreciated...
__________________ SixStrRzr Guitars - Lucille, Cust & Std LP's,Dean,Strats Amps - Marshall JCM-800,Carvin V-3,Mesa MK III,Rocktron Prophesy Effects - Boss, Dunlop wah,U-Vibe MFX - Zoom G9.2tt |
| | #2 | |
| Senior Hollow State Tech Join Date: May 2006 Location: Denver, Colorado
| Quote:
Replace one of the .01uF caps in the vibrato tube circuit with a .022uF cap. With respect to the power tubes idling at 30ma... well, this is not so much the issue as what is the plate voltage vs idle current. If you are using an old worn down 5U4GB, the plate voltage might be low enough that 30ma is OK... personally... setting them to 22ma to 24ma sounds better in these amps. | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| HNY! and a 70's Princeton question. | SixStrRzr | Maintenance, Troubleshooting & Repair | 9 | 01-04-2008 11:44 PM |
| Tremelo problem | hasserl | Debugging Your Build | 13 | 06-14-2007 04:18 PM |
| 70's Bassman tube problems | Marblelee | Maintenance, Troubleshooting & Repair | 10 | 04-09-2007 09:47 PM |
| Questions about my Princeton Reverb | sparky | Maintenance, Troubleshooting & Repair | 27 | 01-21-2007 07:39 PM |
| dumb tube questions | davoux | Maintenance, Troubleshooting & Repair | 13 | 12-30-2006 04:58 PM |
