| | #1 |
| Member Join Date: Sep 2007
| Tony Iommi humbuckers
Anyone have some details on these? A co-worker gave me one of his and asked me to make it sound good. They are epoxy potted, so no chance of a reasonable rewind. Mostly I'm wondering if I pry the external magnet off the back, if it will sound better.
| | #2 |
| Pickup Maker Join Date: May 2006 Location: Montclair, NJ
I'm guessing that's the only magnet? What doesn't he like about them? I weaker magnet will make them darker, and I'm guessing that are dark already. |
| | #3 |
You need to hear them to know what I'm talking about. They have a weird almost out of phase sound that only sounds good with tons of distortion. From what I have read, they have bot a ceramic, and alnico magnet in them.
| | #4 |
| Senior Member Join Date: Jul 2006 Location: Detroit, Michigan
| Got any pictures? I'm wondering if its a spin off the original "birch" design.
| | #5 | |||
| Quote:
This is what they say about them: Quote:
From Iommi's site: Quote:
| | #6 |
| Old Timer Join Date: May 2006 Location: Planet Mongo in the country of PAF
| patents...
JT's name is the key, I think this is the patent? 5792973 |
| | #7 |
| Eureka! I do believe that is it. Wow... very odd. |
| | #8 |
| no shit....
Yeah, it'll take me a week to read it and look at all the little numbers and read all the lawyer talk, but it is one weird ass pickup design, worth studying.....
| | #9 |
| Senior Member Join Date: May 2006 Location: Phoenix
| Pickup punditry
I am guessing that the original Diggins design (specifically the complex magnetic fields that provide the slight phase cancellation) was a happy accident, and that the Gibson version is essentially, a reworking of that design. This looks to me like a pickup that was envisioned, then possibly modified in an attempt to get an even string response with no dropout on bends. The slight phase cancellation was likely a fortunate, but unintended side effect, that now, almost 30 years later, Gibson has patented. If J.D. was really that brilliant at pickup design, i.e. conciously manipulating the magnetic field orientations within a pickup to affect tonal response, you'd think that he'd at least kinda remember something about constructing the originals. IMO, it seems that he probably threw a bunch of things together and that's the one that stuck. Interesting, though, 'cause it really doesn't look like what you'd expect under the cover, does it? any more pundits care to comment? |
| | #10 |
If you read the patent there is no claim of phase cancellation nor any explanation of how the magnets affect anything, disappointing. Its hard to tell where the magnets actually sit, it looks like the top small magnet sits above the coils and the two longer ones that sit on top of eachother are below the coils and the blades contact both? Could have had a better drawing or more detailed drawing of assembly. I'm not so sure the bottom two magnets are even needed, I bet at least the second one up from the bottom could be eliminated with no change in tone. Where is the phase cancellation happening? steel blades will always spread the magnetic flux out to its ends, yet we have these magnets seemingly trying to force the flux inwards or some weird thing. Its obvious that they don't even know whats going on in that design because there's no real mention of what forces are doing what :-) To me it would seem the smaller alnico II magnet at the top would just add more metal and thus tone down the treble response, all the magnets are oriented in the same direction. This is a weirdy.....
| | #11 |
He does seem to say in column 3, paragraph 30, that the upper small magnet causes a "reduction in harsh frequency peaks". At 55 he says "So that the magnet 26 has the desired effect of creating a smoother tonality than is obtained without it, the magnet 26 has a length of about one-third the length of one of the blade-type pole pieces 20." He also states that the upper magnet should be Alnico 2, while the bottom magnets are Alnico 5 and Ceramic 8. But, yeah, why exactly? I can't imagine what the stepped sizes of the magnets would do. This is not the first design to manipulate the magnetic field to get a desired tonal response. Take a look at the two Bartolini patents (3983777, 3983778). He uses planar flat topped pole pieces to get a low flat field. Another interesting one is from jazz guitarist Attila Zoller (3588311) where he uses the orientation of the magnets to shape the field (he called it a bi-directional flux pattern). I think the various Don Lace designs also manipulate the shape of the field with those magnet guides and "fingers". They said in that article that JD didn't remember what he did. I'm surprised they didn't try to X-Ray or MRI the thing. I think JT just messed around with magnets until he got something interesting! (as with all good inventors... Look at Edison and the diode tube, and even the phonograph... happy accidents often based on hunches) The John Birch pickups sound like they have fairly odd construction also. I think this is where "modern" pickups are in a rut. Fender and Gibson designs are pretty normal. You don't see the odd things like DeArmond/Rowe, Rickenbacker, Hagstrom, et al, did anymore. The new Bartolini "classic bass" series claim to have CNC machined blades. It makes me wonder what's so different about them that they need to be machined that way. Maybe they are like his original designs. I've been exploring magnet placement and pole shapes. I think that's where new ideas are yet to be discovered using the traditional wire and magnet pickups, as opposed to the lo-Z current designs. I have some weird ideas I'm going to be trying out. |
| | #12 |
I already gave the pickup back. Trust me, they have their own sound, and unless you're in a Sabbath tribute band. probably not what you are looking for. I've installed 2 sets of these, and heard them OEM in a few other guitars. From looking at the bottom, I believe the most exposed magnet is an alnico. Beyond that, it's all epoxy.
| | #13 |
| phasing...
I think this "phasing" thing is bullshit really, WHAT phasing? You have two blade poles sensing the strings right? OK now add a thick piece of metal to bridge a section between the two blades. You've added extra sensing area and you've added more metal mass creating more eddy currents. I think if you have a dual blade humbucker you could add a small section of alnco II magnet like they do in that design and it would have the identical effect. The stacking of two different kinds of magnets on the bottom must have been done to copy the original without much thought to whether it actually does anything or not. The alnico down there vs the ceramic again is going to load down the treble response so that counts. They probably DID Xray it to see what was going on why else would they have come up with such a strange idea?
| | #14 |
Can anyone post a link....I totally can't find the damn thing!!
| | #15 |
| Stupid connection |
| | #16 |
| yeh....
go here: http://www.pat2pdf.org/ paste in the patent number then when it grabs the pdf it will show up in a blue link, click that to download to pdf |
| | #17 |
Thanks. That was a but better reading. C8 and A2 are sitting on top of eachother in the same direction to the poles- Seems like it would weaken over time..Both are stated as being Northsame to the Blades so sitting on top of eachother Like that could contribute to the overall Phase issue? Fun stuff : )
| | #18 |
| Supporting Member Join Date: Dec 2006
wow, this pickup design is interesting. I have Tony's Star Licks Lead guitar series instructional video from the 80s. He has a really compressed tone. To me, it's almost wierd sounding. Did it mention the DCR anywhere?.....i didn't see it....or am i just blind. |
| | #19 |
No it doesn't have the DCR but it does have the turn count in 44 guage wire, yeah that WOULD sound compressed, I think they were wound fairly hot, and with blades that would really do that....
| | #20 | |
| Senior Member Join Date: Jan 2008
| Getting pickup patents Quote:
http://www.pickupedia.info/Patents The links go to a local copy of the patent. Sometimes, it helps to sort on the "Assignee" column so you can see who has been busy at the patent office. -drh | |
| | #21 |
| Guesstamate!! 6,900 turns 44= 8.8k estimate. safe to say 9k per bobbin. Also depends on the stretch or tension. Probably between 17.8k and 18k
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Humbuckers... well, duuuh... | R.G. | Pickup Makers | 17 | 09-15-2007 03:22 AM |
| magnets for my humbuckers | jj19902003 | Pickup Makers | 12 | 06-01-2007 12:24 PM |
| Anyone have Tony Iommi pickup specs? | R Walker | Pickup Makers | 7 | 11-26-2006 04:22 AM |
| Stacked humbuckers | Spence | Pickup Makers | 1 | 10-19-2006 11:28 PM |
| making humbuckers | franklin01 | Pickup Makers | 6 | 08-18-2006 07:12 PM |
