Old 01-19-2008, 02:04 AM   #1
Question Peavey problem
Looks like the right place to post my problem. As this is my first post may I say hello and happy new year. O.K. that's the pleasantries dispensed with so down to the nitty gritty.
I've blown my horn (Ooo Mrs) on both my Hisys speakers. (ON SEPARATE OCCASIONS). Both crossovers have also blown.
I power the speakers (Peavey Hisys XT series) with a Peavey 2600, (output rating 900 watts per channel)
My question is this: Is the Amp compatible with the Hisys or is it too powerful?
(I kinda think I already know the answer but I was advised, when buying from a reputable dealer that the amp and speakers were compatible.)
All equipment was bought 2nd hand and did work for a good while, then I noticed loud sound cracks coming through. It sounded like someone dropping a tin tray onto a stone tile floor, and then eventually all "top" disappeared.
Hope someone out there can help
Noah Pearly is offline   Reply With Quote
Old 01-19-2008, 03:27 AM   #2
If you have the speakers I'm familiar with, they are rated for 350 watts. So your power amp is capable of blowing them up. But unless your cranking that power amp much of the time I wouldn't expect it. 700 watts is an awful lot of PA power. The amp can't blow up the speakers just because it's rated at 900 watts. You have to turn it up really loud to make it do that. Those speakers do have specific connections in the back to properly operate the crossovers. Do you know if you've been plugging them in correctly?
The fact that your crossovers are toasted too is more indicative of overpowering the speakers rather than plugging them in wrong.
Other than that I can only say that if I had to bet on which speaker was going to go first in a PA cabinet, I'd bet on the horn. Most brands make a point out of advertising how sturdy THEIR horn is because people know they're gonna fail first.
Chuck
Chuck H is offline   Reply With Quote
Old 01-19-2008, 05:10 AM   #3
What exactly do you mean by the crossovers being "blown?"
Peavey 400BH problem Drewn Music Electronics 17 05-02-2009 08:29 PM
Peavey 2000 problem drewl Maintenance, Troubleshooting & Repair 12 07-09-2008 05:34 AM
Peavey Mark3 head problem hostile1 Maintenance, Troubleshooting & Repair 5 09-26-2007 05:50 AM
Peavey 6505+ problem Conqueror Maintenance, Troubleshooting & Repair 2 04-19-2007 12:32 AM
Peavey ULTRA PLUS crunch sw problem Amptek Maintenance, Troubleshooting & Repair 7 08-23-2006 06:28 PM
