+ Reply to Thread
Results 1 to 20 of 20
Thread: counting the number of turns
    Aug 2006
    14
    i was wondering if anybody has an inexpensive way of counting the number of winds when winding a pickup, i have built a homemade pickup winder with a motor and a speed control knob, the only thing i dont have is a way to count the number of turns, please help!
    thank you
    Senior Member Tom Phillips's Avatar
    Jun 2006
    California, USA
    696
    Making a winding counter out of an old calculator
    Check out the info at the following link and let me know if the idea helps you out.
    http://europa.spaceports.com/%7Efish...nter/count.htm
    Regards,
    Tom
    Aug 2006
    14
    calculator counter
    this was the very first method that i tried and i was hoping it would work out, but for some reason the solder wouldnt stick to the board, it seems that one every calculator i had there was a protecting layer over all of the circuits, if you have any more info on how to get around this though i would be more than greatful, thanks
    Jun 2006
    California, USA
    696
    Quote Originally Posted by franklin01 View Post
    ... for some reason the solder wouldnt stick to the board...
    That protection layer is the solder mask. I ususally remove it by scraping with an xacto knife or carefully with a dremel tool. Another idea is to follow the trace to which you want to attach to an exposed solder joint that will take the solder.
    Tom
    ken
    ken is offline
    Senior Member ken's Avatar
    Oshkosh, WI
    446
    You can also try some acetone at the spot on the board you want to solder to.
    Just put some on with a cotton swab, wait about 10 seconds or so, and scrape off with a razor blade.
    Ken
    212
    Look into KEP electronic counters. And Hall-effect sensors.
  7. #7
    ken
    ken is offline
    Oshkosh, WI
    446
    I have a CUB4 around here somewhere I want to use myself.
    I'm thinking about 'trading in' my infrared counter sensor for a Hall Effect one,
    how do I interface the Hall sensor to the Cub4?
    Ken
  8. #8
    Boston, MA area
    1,466
    Quote Originally Posted by ken View Post
    Ken
    By picking the right Hall sensor. Many are designed for just this kind of thing, with an output that switches between open and closed. You need one that's able to handle the ~3-volt, 100-microamp sensing signal from the CUB4.
  9. #9
    ken
    ken is offline
    Oshkosh, WI
    446
    I guess I better look at the Mouser catalog then, I like the big numbers the CUB4
    has but I'm not overhappy with the IR sensor.
    Ken
  10. #10
    MKB
    MKB is offline
    Jun 2006
    28
    I'm using a surplus counter with a Hall-effect sensor. The sensor drives the gate of a MOSFET, which then pulses the +12V to activate the counter. Interfacing the winder with the Hall effect is super simple, just stick a Radio Shack rare earth magnet to the shaft of the winder, and then move the hall effect near the magnet. As the shaft and magnet spins, it then activates the hall effect. My winder uses a variable speed drill, the magnet is placed on the chuck. I usually run the winder not too fast, so the magnet does not try to fly off.
    The counter is a surplus +12V pulsed counter bought from a surplus house for $1 or so. It does not have a reset function, but it is simple to add the number of turns desired to the count at the start of the winding. This system has worked extremely well so far.
  11. #11
    Dec 2006
    Australia/ Hong Kong
    28
    Hmmm. Winders.
    I remember my first winder was made by ripping the guts out of a cheap clock. I just hooked up the spindle to the seconds shaft and that was it. Some simple maths and it's a reasonable counter. I found that i could spin them well up to about 300 rpm in both directions without any problems.
    Now i rely on mechanical counters rather than electronic digital counters. My winder's not fast enough to induce any problems with mechanical counters. It's not that I'm cheap, it's just that I'm..... well.... Yeah. Cheap.
  12. #12
    Old Timer Spence's Avatar
    The Dog House
    1,438
    Mechanical Counters
    Try this :
    http://enmco.thomasnet.com/category/...anical-counter
    Should be OK even if you're winding at warp speed.
  13. #13
    Boston, MA area
    1,466
    Quote Originally Posted by Spence View Post
    Try this :
    Be sure to get a "rotation counter", not a stroke counter.
  14. #14
    ken
    ken is offline
    Oshkosh, WI
    446
    Being cheap is no sin, after all not having money is a great reason to innovate.
    Anyone can solve just about any problem simply by throwing money at it, IMHO being broke makes one think about the best way to do things.
    I bet you will soon outgrow the mechanical counter, electronic counters are much more stable and will allow winding at higher speeds than the mech. ones.
    Ken
  15. #15
    Supporting Member David Schwab's Avatar
    Montclair, NJ
    6,713
    Quote Originally Posted by Brock Little View Post
    Hmmm. Winders.
    How did you get an electric clock motor to spin at 300 RPM? The 60 cycle wall current sets the speed of an electric clock to 1 RPM (in the US anyway).
    My first winder was made with a sewing machine motor, along with the variable speed pedal. Alas, it had no counter! I had to wind a bit and check the DC resistance.
    I think I'll hook a speed pedal up to my current winder... it was handy.
    "I will suppose... that some evil demon of the utmost power and cunning has employed all his energies to deceive me." - René Descartes
    www.sgd-lutherie.com
    www.myspace.com/sgdlutherie
    www.myspace.com/davidschwab
  16. #16
    Dec 2006
    28
    It was a battery operated analogue wall clock with a traditional circular face, not a digital style or the old 'flick' style. These clocks are as cheap as dirt, I didn't even have to go out and buy one, it was in the lounge room all along.
    It's just a matter of removing the single AA battery and yanking off the seconds hand. This exposes the small shaft in the centre. Just have a quick look at the centre shaft and it's easy enough to work out from there.
  17. #17
    Montclair, NJ
    6,713
    Right, I got all that.... but how did you make it go 300 RPM? The battery powered clocks use a quartz crystal to set the speed. Second hands on clocks travel at 1 RPM.
  18. #18
    The Dog House
    1,438
    I suspect he was using the clock as a counter, driven by the winder.
  19. #19
    Dec 2006
    28
    Sorry guys. I thought that was kinda obvious.
    The idea came to me because you can wind the hands of these clocks to set the time. by removing the seconds hand then you have the central shaft exposed and you have the means to count each revolution by running an extension from the winder.
    I was in the process of making a reducer for the crappy old winder i was using so i could get higher speeds from the winder without having to run ye olde clock at warp speeds. Then a better winder made itself available (read: better funds became available for new winder).
    It's not very hi tech, but as has been implied, nothing inspires innovation like a shallow pocket.
  20. #20
    Montclair, NJ
    6,713
    Ah, now I see it...
    Nothing is ever obvious to me! Not even the obvious... the obtuse I see with no problem however!
    ...nothing inspires innovation like a shallow pocket.
    I agree. I've invented some cool stuff because I couldn't afford to go out and buy something... I started building basses because I couldn't afford what I wanted.. only to spend much more on machines!
+ Reply to Thread
