Go Back   Music Electronics Forum > Instrumentation > Guitar Tech
Old 01-23-2008, 10:55 AM   #1
Supporting Member
Steve A.'s Avatar
How do the mini-hb mounting rings work?
These look like the ones that fit into a P-90 rout like on a 70's LP Deluxe. Allparts sells them, but I have no idea how you are supposed to secure them to the guitar. (I had made my own, cutting P-90 covers with my Dremel, but to mount them in the guitar I used hot melt glue- not exactly the best solution if you were to tour in Arizona! LOL)
Here's a link to the page:
http://www.allparts.com/store/pickup...28,Product.asp
Thanks!
Steve Ahola
Steve A. is offline   Reply With Quote
Old 01-24-2008, 12:46 PM   #2
the pickup and ring are assembled as one unit. The 'height' adjustment screws do not adjust the pickup in the ring, but adjust the whole ring/pickup assembly by raising/lowering into/out of the guitar body, kinda like P-90 soapbars. the adjustment screws thread into body mounted inserts, or into a plate mounted at the bottom of the pickup rout.
The mini-hum is kept at a predetermined height within the ring by the use of a standoff, and is permanently mounted in the ring by the use of a soldered nut on the bottom of the pickup legs.
Sweetfinger is offline   Reply With Quote
Old 01-24-2008, 04:31 PM   #3
Supporting Member
Steve A.'s Avatar
Thanks for a very clear explanation! Now I guess I can retire my hot melt glue gun...
Steve Ahola
EDIT The rings from Allparts do not include the backing plate so I guess you would want to sink a threaded insert (or nut) into the wood under the ring. Or maybe one of the boutique winders makes the plates...?
Old 03-02-2008, 12:30 AM   #4
I've pondered this meself, but I just can't discard the 90's. Even though I'd love to
have a Firebird thing goin' on.
socalscott is offline   Reply With Quote
Mounting speakers Bernardduur Cabinetry 4 12-15-2007 12:23 PM
Shock mounting tubes? Steve Conner Theory & Design 30 09-28-2007 05:12 PM
Z-mounting a stand-up Matt T. Theory & Design 4 04-30-2007 01:49 PM
Opamp 'polarity'/ mounting Qs The Captain Guitar Effects 4 04-19-2007 10:32 AM
Pick-up mounting rings sfsr68@optonline.net Repair and Restoration 5 03-19-2007 08:56 PM
