Results 1 to 6 of 6
Thread: eico 666 tube tester
    Senior Member Mars Amp Repair's Avatar
    Sep 2006
    Englewood, CO
    810
    he folks,
    does anyone have experience with this tube tester? I am having trouble even finding the rectifier diode...if there even is one.
    When I attempt the 'Merit' test with the appropriate buttons pressed to do so (I am assuming those are the ones that are underscored on the roll sheet) the needle just 'hums' like it has AC on it. I do read DC plate voltages on the tube to be tested.
    I have cleaned all the switches & such.
    I tried to trace the Line voltage test as it seemed the easiest to follow, but NOT
    Any help appreciated...glen
    Senior Member Enzo's Avatar
    Lansing, Michigan, USA
    18,036
    "Eico 666 schematic"
    Enter that in google and check out the results.
    Jan 2008
    4
    I just got one of these , the underlined number does nothing until you press the (?h/k leak button?) going off memory here, the very last number is the merit so you push in the numbered button then pull the merrit switch. here are some links i found for instructions and stuff. One is a newer diode/rectifier and caps ou can put on it. I cant zero in the needle on mine, like the line button doesnt work, needle works fine on a teat though. i do know that they used the cheapest parts possible on these and the charts are very inaccurate so be careful w/ your tubes
    stock diodes
    http://www.leedselect.com/parts-odds.html
    schematics and manuals
    http://bama.edebris.com/manuals/eico/666/
    mods and repair
    http://www.tone-lizard.com/Eico667_troubleshooting.htm
    Quote Originally Posted by Mars Amp Repair View Post
    he folks,
    18,036
    There must be a rectifier. From that era, it just might be selenium. Is there something with a few square metal plates, almost looks a little like a radiator pipe for a hot water heat sysytem except only a few plates.
    Jan 2008
    4
    There are 2 of them, i believe they name was selenium diode as Enzo said. heres a layout pic i have, looks like they are in the vicinity of the what looks like some sort of internal adjustment pot. diode is marked CR1 the other is CR2 but is not on the layout.
    Sep 2006
    Englewood, CO
    810
    Wow...great info. Yeah, the closest thing I found was a black square thing that you have circled in your drawing...I didn't know what it was. There aren't many filters anywhere in this thing. from the schematic link provided by Patiam, I can see how rudimentry the power supply is for this. I guess they didn't need anything any more complicated.
    This info will make fixing this thing easy..thanx, glen
  1. ecc83 nos test in TV7 tube tester
    By Andrei_T in forum Guitar Amps
    Last Post: 09-27-2007, 06:08 PM
  2. Pickup Tester, not a driven coil
    By R.G. in forum Pickup Makers
    Last Post: 08-03-2007, 07:28 AM
  3. error on small bear Fuzz Face transistor tester?
    By dai h. in forum Guitar Effects
    Last Post: 07-16-2007, 03:01 AM
  4. Eico 950 B
    By studioit in forum Maintenance, Troubleshooting & Repair
    Last Post: 04-24-2007, 07:16 AM
  5. How to use a tube tester
    By MitchK in forum Maintenance, Troubleshooting & Repair
    Last Post: 04-19-2007, 09:38 PM
