| | #1 |
| Junior Member Join Date: Aug 2006
| Deluxe Clone Farting Problem
Greetings: I have a hand wired, blackface Deluxe clone with a very loose bottom-end when hitting a power chord or just playing loud low note when amp is moderately loud (5 or 6). The amp has Weber PT, Merc MagAxiom OPT, Weber 12V 50W speaker. The problem sounds like a stressed speaker but I've ruled that out. *Played another amp though speaker...OK *Hooked-up my BFDeluxe to a 4x10 cab, made same noise. *Swapped out all tubes, still the same. An amp tech friend seems to think there's a problem with the feedback ckt. Any thoughts? Andy |
| | #2 |
| Senior Member Join Date: Jul 2006 Location: Baton Rouge,LA
Could very well be feedback in more than one form or another. Leo had a real knack for running wires a certain way and it could certainly be your problem also or a bad connection somewhere. Check all of your solder joints real well and make sure they are ok. Most will say it's filter caps as motor-boating is caused from insufficient filtering but IMO that's not the case. Heater wires not cancelling will do it to but usually in a buzz form. I re-did this amp a few months back that was doing the same thing except it was also high freq. oscillating. I even called Bruce and we went over the legistics but heres what finally fixed it. I put a 500pf cap from the treble wiper (pin 2) to ground and that stopped the farting. Then I moved the wire from the phase inverter off the coupling cap that goes to the grid resistors of the power tubes and routed it around the first preamp tube socket and all the noise went away and everything was good. You would be surprised what moving wires around can do in amps like this but it can be dangerous when idling and moving wires. Try finding pictures of a blaceface Deluxe board or a wiring diagram and make sure they are run the same way.
__________________ KB |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Fender Classic Clone/DIY` | bkloos | Guitar Amps | 1 | 08-10-2006 02:14 PM |
| intermittent problem on a deluxe reverb | kaiomenos | Maintenance, Troubleshooting & Repair | 3 | 07-06-2006 04:15 AM |
| 5E3 Deluxe - 100 Ohm Res. Hookup ??? | oldave | 5 E 3 | 3 | 06-06-2006 12:48 AM |
