| | #1 |
| Junior Member Join Date: Feb 2008
| stupid nOOb question
Hello As the title suggests, i have a question that you'll probably all know the answer to. Nevertheless, here it is: I have an epiphone valve junior, which has an EL84 and a 12AX7. What difference would it make if i changed the EL84 for, say, an EL34? Will it work? Or will it sound awful? Do the numbers mean anything? I'm pretty clueless... Thanks Robert |
| | #2 |
| Supporting Member Join Date: Jul 2006
Sorry Robert; It won't work. There are plenty of simple mods for that amp though. Before you dive in study some. Here's a good start. Jack Darr Book |
| | #3 |
| Senior Member Join Date: Jan 2008 Location: Galashiels, Scotland
| Valve change.
You'd have to drill the chassis for a larger valve base as the EL34 is an octal, whereas the EL84 is a B9a, and wire that up. Then the heater would probably demand too much current( the EL34 takes 1.5A, the EL84 - 0.76A), so youd need a new mains transformer. Change the Cathode resistor to 330ohms, and do various other tweaks to get it to work properly. This may sound like i'm taking the piss, but many years ago I did this and ended up with an amp that sounded almost the same as the one I started with. |
| | #4 |
Thanks for the info, i think i'm slowly beginning to understand it all. I do know one thing for sure - i should have payed attention in Physics class! |
| | #5 | |
| Supporting Member Join Date: Feb 2007 Location: Wellington NZ
| Quote:
Ya happen to have the other chapters to that book .pdf'd there by any chance (or a web source for the same)? (Cain't get anything like them old-timer books in the Southern hemisphere). Cheers | |
| | #6 |
| | #7 | |
| Member |
hello. Quote:
http://www.pacificrecone.com/JackDarrBook.html greetings from vienna... | |
| | #8 |
| Member Join Date: Oct 2007
You might want to check out www.sewatt.com There is a dedicated Valve Junior forum there. You will have to sign up to view the forums, though. A few of the posters have put in 6L6s, EL34s and one guy even put in a KT88. The Valve Junior's power transformer seems to be capable of supplying current for all the aforementioned tubes. chuck |
| | #9 |
Many Thanks oahu I love the bit in the Chapter on Customer Complaints where he says: "You must work on the assumption that the guitar and amplifier were practically distortion-free when new, and try to make them work as well as they did then." Shows how times have changed. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Really stupid pickup question - | Todd Hepler | Pickup Makers | 7 | 11-26-2009 07:27 AM |
| may be a stupid question, but | gscontr | Lobby | 0 | 11-27-2007 04:41 AM |
| Potentially stupid question concerning OTs | greg | Theory & Design | 1 | 10-01-2007 08:27 PM |
| Quick (and probably stupid) rectifier question | Turbo7MN | Guitar Amps | 5 | 09-11-2007 09:55 PM |
| Noob Humbucker Start Lead Wire Question | PoorMan | Pickup Makers | 4 | 05-10-2007 07:42 AM |
