To me,the voltages look to be "in the ballpark" and dont point to any reason you get no signal to the speakers.Can you do some signal tracing?Find out where you are losing the signal.You should put a signal generator in the input and then trace the circuit,starting at the input and proceed to the output cap of the first preamp tube and so on, to see where the signal is not passing.
LinkBack URL
About LinkBacks
These jacks came from a local store and where individually
