Old 08-29-2006, 08:18 AM   #1
Tranny's How to tell ? Where to get ?
Ok , i have three tranny's in my dr.z maz jr with reverb. where can i get a set to build a clone of this amp.
here are the numbers ... on the big black tranny it has
DRZ-5001
EIA606
MS 1-37
Next is the medium size one silver
DRZ 7002
CIN- TRAN 3399
30-0116
Next is a small one also silver
DR.Z 5003
CIN-TRAN 2580
30-0121
mtx11 is offline   Reply With Quote
Old 08-31-2006, 03:37 AM   #2
amplover's Avatar
Why dont you call him and ask him for them?
amplover is offline   Reply With Quote
Old 09-01-2006, 04:57 AM   #3
Cin-tran appears to be a transformer company in Cincinnati, OH and it sounds like two of those are made by them and the following numbers might be model numbers. You might do well measuring the power transformer output and picking up a similar spec one.
Thorny is offline   Reply With Quote
Old 09-01-2006, 08:55 AM   #4
That might work, but be warned. Most suppliers make parts to spec. Even if it is an off the shelf item it may still be considered proprietary. WHile you might get somewhere with them, they most likely will politely refuse to discuss the part with you because it is a Dr.Z part. Those numbers may be assigned to him. Just like all those SJ numbers on Motorola power transistors for various amplifier makers. AFter all, if all a competitor had to do to get the skinny on your part was call the part maker, there would be chaos in industry.
And the worst thing that can happen if you call Dr.Z is he won't discuss it, but he might be happy to. Worth a try.
Old 09-01-2006, 06:28 PM   #5
Supporting Member
Steve Conner's Avatar
I'm sure Dr. Z would rather you bought an amp from him than cloned it. Anyway, I noticed you said "My Maz Jr." Why do you want to clone an amp if you own the real thing already?
Steve Conner is offline   Reply With Quote
