Old 02-27-2008, 04:40 PM   #1
Peavey 6505+ blown fuse F1
http://www.schematicheaven.com/newam...ey_5150-II.pdf
Amp stopped working....no sound, standby lamp not lighting. Fuse F1 (2AFB) was blown. I replaced the fuse, everything powered up fine. I played my Ipod into the input, output into a hotplate set to 'load', ran it at high volume settings for 20 minutes.....the fuse held, and all seems ok.
what would cause this fuse to blow?
acorkos is offline   Reply With Quote
Old 02-27-2008, 06:01 PM   #2
Dying (maybe now dead) power tube. Are off of the output tubes glowing & warm?
It is possible that a heater failed & caused a temporary problem. If the leftover pieces inside aren't touching anything it could power up fine (just not sound so good, you're down a tube).
It also could have been an arc in a power tube that blew it. Problems with the OT or any connecting / disconnecting loads while the amp is live could possibly do that. If that was the problem there may be no permanent damage.
cbarrow7625 is offline   Reply With Quote
newbie bf champ blown fuse, cracked resistor sheppadizzle Maintenance, Troubleshooting & Repair 5 12-04-2007 07:43 AM
Possible blown fuse...? madpigpunk Maintenance, Troubleshooting & Repair 2 10-09-2007 06:30 PM
Arcing in Rectifier then blown fuse? alexg Debugging Your Build 9 08-08-2007 07:16 PM
Peavey 6505+ problem Conqueror Maintenance, Troubleshooting & Repair 2 04-19-2007 01:32 AM
Peavey 6505/5150 biasing problem? markyb Maintenance, Troubleshooting & Repair 5 12-05-2006 05:47 PM
