have a 70’s Ampeg V4 with no history. It was plowing the fuses; I narrowed it down to the two pairs of diodes D7 – D10 tested as a short. When I disconnected the diodes the fuses held and the amp powered up with all of the correct voltages (no power tubes) One of the power tubes (7027) was missing (might have been the culprit). I’m waiting to receive a new tube to try everything under power.
Does the amp really need these diodes; are they there to prevent a catastrophic failure if the power tubes shorts?????
If so, I’m have trouble finding the exact value replacements
Thanks
