| | #1 |
| Junior Member Join Date: Jan 2008 Location: USA-NY-Rochester & NYC
| Wind round, then mount on bobbin?
I was wondering if anyone uses, or any company maybe formerly used, the following method. (Sorry if this has been covered, but I didn't get it with a search.) What if you were to wind a coil on a round drum, then remove the coil and "stretch" it over a properly shaped core? I would think that, while bringing up a new unique new set of issues, this method might allow a much faster coil winding, since the wire feed rate and tension would be constant instead of the usual near-stop-start, allowing you to work up to a much higher RPM. Has it been done? What would be the pros and cons? Thanks Pete |
| | #2 |
| Senior Member Join Date: Jun 2007
All I can say is I wouldn't try it even at gun point. Have you wrapped any pickups yet? It's hard enough winding on a bobbin and not breaking or shorting a wire.
| | #3 |
| Senior Member Join Date: May 2006 Location: Cornelius, Oregon
The old Burns Tri Sonics were an air coil, and they were wound on a removeable former, then wrapped with a sort of string, then the former was removed and the coil was stuffed inside the cover with the magnet and epoxied. These are similar to your idea, but not quite the same. You'll notice that they didn't move the coil at all in any way until it was wrapped. With your example, the coil would fall apart if not wrapped with something to hold it together, and stretching it would break it. Greg |
| | #4 |
What if the round pre-assembly coil was wax-potted prior to removal, then gently warmed to pliability before removal and relocation? Or is that still too risky? What COULD work (though only in theory) might be a pliable bobbin that could be round to start, then gently warmed to pliability and reshaped. Assuming such a compound a) exists and b) is suitable for bobbin dimensions with the requisite sturdiness and pliability. |
| | #5 | |
| Pickup Maker Join Date: May 2006 Location: Montclair, NJ
| Quote:
Q-tuner pickups are wound on a form using bondable magnet wire, which is then bonded in an oven, and the coil is removed from the form. They are self standing air coils.
__________________ Those who create are rare; those who cannot are numerous. Therefore, the latter are stronger. - Coco Chanel www.sgd-lutherie.com www.myspace.com/sgdlutherie www.myspace.com/davidschwab | |
| | #6 | |
| Quote:
The goal is conversation, not conversion. Re your other comment, I was thinking that the even tension during winding would eliminate pressure points at the ends, and the cyclic accel/decel of the wire, maybe helping with both breakage and shorting problems. | |
| | #7 | |
| Quote:
Also, I didn't mean actually stretching it, what I meant was re-shaping it. Last edited by pilotjones; 03-05-2008 at 10:28 PM. | |
| | #8 |
Mark and David, I was thinking of some ideas similar to yours. Also, another one I had: round drum; put around this a piece of rubber or silicone tubing that has been slit lengthwise, and is properly cut to encircle the drum once; slit facing outwards. There are two rows of clips of some sort, one on each side of the tube, to pry back and hold open the slit. Neglecting details of start and stop termination, you would wind into the rubber groove thus formed, release/remove the clips, and pull off a nicely constrained but still flexible air coil. Potting material would of course have to be able to penetrate the slit, and it would have to be seen whether the contained air could be made to exit the tube to pot properly. |
| | #9 |
| Senior Member Join Date: Jun 2006 Location: San Pedro, Laguna, about 45 minutes to an hour from Manila
There's only one way to find out if it's worth the trouble. Do it and post your results. I'm sure they will be aprreciated.
| | #10 | |
| Quote:
I just remembered another way I was planning on doing it was to make a form with two dowels (for each end) and wind a regular shaped coil, bond it, and remove it from the form.
| | #11 | |
| Quote:
These types of things were done all the time on old pickups. You see paper bobbins and stuff like that. Alembic makes their pickups from PC board material... they just glue two pieces onto a magnet to form the bobbin. On the stacked pickups, there's one more sheet with a plastic core. making anything that doesn't have "standard" available parts is always a chore. You either have to hand make the parts, or invest in injection mold tooling.
| | #12 |
| Old Timer Join Date: May 2006 Location: PDX
Jones I don't see a problem doing it this way. Electric motors are rewound this way and it certainly works for them. I like the idea of a thermoplastic form, perhaps something like poly-form plastic. You can dip it in hot water and reshape it to your hearts content but it goes completely rigid at 110º or something. Actually come to think of it, transformers are sometimes wound this way too. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Vibro King - Round Four | mikeboone | Maintenance, Troubleshooting & Repair | 0 | 12-11-2007 10:45 PM |
| Confused about wind direction (help?) | Kelby | Pickup Makers | 7 | 10-03-2007 01:33 AM |
| Mini-hum mount screws | Zhangliqun | Pickup Makers | 5 | 09-18-2007 12:09 AM |
| Wind Direction and Mag Polarity | PoorMan | Pickup Makers | 5 | 08-30-2007 02:39 PM |
| Nashville 400 (Round 2) Hot Hummmm | psmith | Maintenance, Troubleshooting & Repair | 4 | 08-12-2006 03:55 PM |
