Go Back   Music Electronics Forum > Amplification > Guitar Amps > Theory & Design
Old 03-08-2008, 04:35 PM   #1
Hammond 125C for SE use?
A little background: I'm currently designing a small amp, power stage is two 6DG6GT's in a parallel SE configuration. My PT (after rectification, filtering) should provide ~170 -180V, about 7 watts of audio power. I'm anticipating a load resistance in the 1500-1800 ohm range.
I'm having a tough time finding a SE OT in that range--most are 2500 ohms or above.
The Hammond 125C (8W) definitely fits my needs. With a 4 ohm speaker, 1500 ohms is a spec'ed setting. Several references: Angela.com, london power, the Hammond catalog, etc. indicate this iron works as both SE and PP.
But the Hammond website that references it's own catalog pages indicates I should look elsewhere for an SE transformer. I suppose I could punt and change the design to PP....
gmoon is offline   Reply With Quote
Old 03-09-2008, 01:36 PM   #2
To restate the question:
Has anyone used any of "universal" Hammonds: 125C, 125D, 125E as single-ended OTs?
Old 03-09-2008, 03:39 PM   #3
Chuck_Farlee's Avatar
It used to be that Hammond advertised the 125A-125E series as universal push pull and single ended replacements. This is before they started selling the 125ASE-125GSE which are true single ended output transformers. The 125A-125E OTs are really push pull transformers. After the SE series came out, Hammond dropped SE use from the 125A-125E series.
I've used the 125E in several champ builds and it works okay, but the 125ESE sounds much better.
I would use the 125E if you wanted to try your circuit, it can tolerate more DC in the core.
chuck
Chuck_Farlee is offline   Reply With Quote
Old 03-09-2008, 09:23 PM   #4
Thanks, Chuck
Could a 125ESE be used in a 1250 ohm mode? It's unspec'd, but if you follow the connection diagram, it looks as though Black & White would == 1250 ohms with a 4 ohm speaker.
Not spot on, but close. Since the 125ESE is good to 15 watts, 1/2 that wattage as an outa spec load might work?
Taking a second look at the load resistance graph, it doesn't seem at all terrible running one @ 5000 ohms, so 2500 for two might work just fine.... (two 6DG6GT's, that is.)
Hammond L-100 conversion Rafael Conversions 15 12-20-2009 07:02 PM
Hammond PR20 amp, 3-in-1 amp? Brad1 Other Amps 7 04-15-2008 03:15 PM
Hammond OTs as replacement Alex R Maintenance, Troubleshooting & Repair 1 01-28-2008 04:17 PM
best hammond OT for HRDL? Alex R Maintenance, Troubleshooting & Repair 0 01-07-2008 05:32 AM
Hammond L-100 resurrection? Leka Other Amps 2 10-07-2007 05:18 PM
