Old 03-10-2008, 08:47 PM   #1
Fender Ultimate Chorus - bad hum
I have a Fender Ultimate Chorus, its about 9 - 10 years old, not the DSP. It now has a horrible hum when turned on. Even with no guitar plugged into the amp. If I turn the chorus on, the hum gets even louder and bassier. Sound still comes out if I plug a guitar in and play, but there's crackle and fizz with all the notes.
Any help or thoughts would be appreciated.
drp555 is offline   Reply With Quote
Old 03-10-2008, 10:04 PM   #2
Two things come to mind immediately:
1.) Cracked ground trace (input jack maybe?) that is disrupting the ground continuity in the circuit.
2.) Filter caps. Have you checked them? Do you have the proper DC running through the amp? How much ripple do you meause on the DC rails?
Filter caps would be a 120Hz hum. Ground trace would be 60 Hz. Can you tell which it is? I don't know what piano notes those two frequencies are off the top of my head but I'm sure someone else here can tell you. If you can figure out the tone, you will be that much closer to solving your problem.
cbarrow7625 is offline   Reply With Quote
Old 03-11-2008, 01:05 AM   #3
FLip the main board over and check the solder to the main filter caps. I bet it is cracked - resolder them.
Enzo is online now   Reply With Quote
Old 03-14-2008, 12:48 AM   #4
Thanks guys. I got a chance to check out the board today. Turns out one of the filter caps did have a cracked solder joint. I fixed that up and now everything is good.
Old 03-17-2008, 01:05 AM   #5
had the same problem. Thanks for the fix.
grcarson is offline   Reply With Quote
Old 06-01-2008, 03:02 PM   #6
Ultimate Chorus issues.
Had the same issue here. Fixed that but the reverb doesnt seem to work although when I tap on the reverb unit I can hear the effect thru the speakers. Any ideas?
Showey is offline   Reply With Quote
Old 06-02-2008, 09:57 PM   #7
Quote:
Lunched rev drive IC is likely. Or a bad coil/connection to the coil on the drive side.
Gtr_tech is offline   Reply With Quote
Old 06-05-2008, 04:03 AM   #8
I found it. bad coil on the INPUT side of the reverb tank.
New reverb can installed 20.00 from ebay and all is well!
Thanks!
Old 06-05-2008, 10:59 PM   #9
Today I swapped it for a Peavey Delta Blues 115 Tube Combo Amp.
I think its a good thing?
Fender m80 chorus brick8 Maintenance, Troubleshooting & Repair 17 01-23-2008 04:05 PM
Fender Ultimate Chorus with broken chorus Notafraid Maintenance, Troubleshooting & Repair 12 01-18-2008 01:13 AM
Fender Ultimate Chorus Problem.....Listen to audio files kozmo Maintenance, Troubleshooting & Repair 0 11-21-2007 01:23 PM
S.o.s M80 Fender Chorus Amp ASIK Maintenance, Troubleshooting & Repair 2 07-19-2007 02:44 PM
Fender Ultimate Chorus heads-up Mark Black Maintenance, Troubleshooting & Repair 1 04-03-2007 03:00 AM
