Go Back   Music Electronics Forum > Amplification > Guitar Amps > Theory & Design
Old 03-12-2008, 03:38 AM   #1
Simulating a 10 meg pot with a rotary switch
The tremelo circuit I'm using requires a 4 meg reverse-audio pot for the speed
control and a 10 meg reverse-audio pot for the intensity control :
I've bought these pots from Weber but am not terribly impressed with their
quality.
I'd like to simulate these pots using a rotary switch for a range selection and a
1 meg reverse-audio pot for fine adjustment. This works well for the speed
control, which is wired as a rheostat :
(leaving aside the fact that the resistors could be adjust to better reflect a
reverse log taper)
I have not been able to come up with a similar circuit for the intensity
control since it's wired as a potentiometer :
I could use just the rotary switch as a stepped attenuator but I'd like to use
a pot for fine adjustment within a step.
Is there any way to do this ?
Paul P
Paul P is offline   Reply With Quote
Old 03-12-2008, 05:04 PM   #2
I think your overcomplicating things a bit. For the speed control, try a 3M RA pot. These are available from various sources and not too expensive. The basic oscillator is the same as in every other Fender amp, and they all use 3M pots. If you *really* need 4M, use a 3M pot and add a switch to insert an 1M series resistor.
For the depth control, I think fine tuning is not really necessary. Lots of old amps had no depth control at all for their tremolos, others (e.g. Vox) had just two preset depths. So with a 10 position rotary switch, you'll probably get all the control you need. However - don't use 10 x 1M resistors. That would give you the same sweep as a linear pot. That would result in probably just one or two usable switch positions.
To get the correct reverse log taper, use a series of increasing size resistors, e.g. 100k + 180k + 330k + 560k + ... that make up a total of about 10Meg. The total resistance value should not be that important. Anywhere between 5M -15M is probably OK.
d95err is offline   Reply With Quote
Old 03-12-2008, 06:25 PM   #3
Thanks for the reply d95err. I just got the tremolo circuit up and running
and I can now agree that you don't need all that many different intensities
and that a fine tuning pot is unnecessary. I used a bunch of 1meg resistors
because I had them and I'll have to order ones to give me a better spread,
but it's pretty obvious that there's a lot of change at one end and little at
the other. Still, I should be able to use what I've got to figure out better
values.
Paul P
Old 03-14-2008, 02:41 AM   #4
Quote:
Originally Posted by Paul P View Post
Still, I should be able to use what I've got to figure out better values.
Combinations of series and parallel? It eats up a lot of resistors, but if you have a bucketfull anyway ...
One thing I remember futzing with was a spreadsheet to calculate 20 or so values on pots of various fake tapers. I'll see if I can find that and post or forward it.
Hope this helps!
Don Moose is offline   Reply With Quote
presence on off switch scole Tweed Builders 5 03-25-2008 11:14 PM
To add a standby switch or not? daz Mods & Tweeks 5 02-14-2007 01:38 AM
CK switch on first stage Fred G. Mods & Tweeks 7 01-06-2007 01:32 PM
switch between angelo Guitar Tech 0 08-03-2006 12:18 AM
V-4B Ultra Lo switch Dave M Maintenance, Troubleshooting & Repair 5 06-07-2006 01:12 AM
