Old 03-12-2008, 05:22 PM   #1
Boogie DC-3 headscratcher.
I have a mesa boogie DC-3 that is laughing behind my back and giving me the finger.
It has a horrible low frequency farty distortion on both channels, eq in or out, through the line out and headphone out. Speaker and power amp have been ruled out. Valves have been swapped about. I keep thinking i've got my head around whats going on, have a cup of tea, and realize it cant be.
It looks like severe crossover distortion.
Does anyone know the common problems with these so I can feel i have a direction to head in.
Wakculloch is offline   Reply With Quote
Old 03-12-2008, 07:43 PM   #2
Got a schematic?
cbarrow7625 is offline   Reply With Quote
Old 03-13-2008, 09:29 AM   #3
I wouldn't assume it was a common problem. I'd just assume it was a problem and go from there.
Start with power supply. WHat are the B+ voltages? Are they clean? What voltages are on the power tubes? Are plate and screen up to solid B+ levels? Cathodes grounded right? Proper bias on grids? Clean bias, not rippled?
Go down the row of tubes. Look at voltage on the pins - B+ on 1 and 6, is it OK? Cathodes on pins 3,8 - all have some reasonable voltage? Look at the grid pins. ANy sporting DC voltages that don't belong? Unless they are a cathode follower stage or a split load stage, grids should be about zero DC, within a volt anyway.
Is there an efect loop? Is the signal clean at the send? Or farty? And a clean signal put into the return, is it OK? Or not?
APply a signal to the input, and scope stage by stage to see where the distortion occurs.
Old 03-14-2008, 12:06 AM   #4
Thanks for that Enzo. Pulled me out of "that is illogical captain" thinking, (and annoyance).
Am now feeling more like an incompetent doctor with a sick child who will soon die without diagnosis of an fatal but easily curable disease.
Metered all the anode, grid and cathode voltages; when i got to the phase splitter noticed a hiss from the speakers as i checked the anodes. Tried a guitar signal and all's well.
Assumed bad solder joints on the valve base and re-soldered.
Turned amp back on and problems back.
Checked PI voltages and as soon as the meter probe touches the plate connection it comes back to life; remove probe it fades.
Get narked, come back to it later, re-check voltage, apply probe hear it "cure itself", and now it won't go wrong, but I know all this is telling me something that i'm missing.
All theories received with thanks.
Mesa Boogie F50 Spence Mods & Tweeks 2 02-21-2009 11:49 PM
Mesa boogie 50/50 brewu22 Maintenance, Troubleshooting & Repair 20 11-13-2008 08:34 AM
Boogie parts? casey73 Maintenance, Troubleshooting & Repair 2 01-20-2008 05:31 PM
Oscillating Boogie drewl Maintenance, Troubleshooting & Repair 2 10-28-2007 12:06 AM
Possible mods for Mk1 Boogie? mark Mods & Tweeks 7 08-08-2006 01:55 AM
