| | #1 |
| Member Join Date: May 2006 Location: Mandeville, LA
| How many dB are needed?
What is the range of voltage gain needed for a "typical passive " guitar signal to adequately drive the grids of a set of 6L6 power tubes in push-pull configuration.
| | #2 |
| Senior Hollow State Tech Join Date: May 2006 Location: Denver, Colorado
Depending on the class of power tube operation and the actual bias of the power tubes... usually somewhere between 25vac to 60vac from grid to ground. So do the math and start with 100mv of signal to the first stage and end up with 25vac to 60vac ... MATH ************* I forgot to mention +6dB is twice the voltage gain. Last edited by Bruce / Mission Amps; 03-18-2008 at 04:14 AM. Reason: forgot to add help |
| | #3 |
| I did the math
I get about 48-56 dB Thanks. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Fender M80 help needed | Mooman | Maintenance, Troubleshooting & Repair | 5 | 01-01-2010 01:45 AM |
| Troubleshooting help needed-VHT amp | pine | Maintenance, Troubleshooting & Repair | 7 | 01-16-2008 05:05 AM |
| WEM Copicat SS help needed | Liam | Guitar Effects | 2 | 10-18-2007 01:35 PM |
| 5A5 Pro Amp schematic needed | Derek | Maintenance, Troubleshooting & Repair | 2 | 02-26-2007 12:55 PM |
| any one in the uk, 5e3 parts needed. | 31trum | Build Your Amp | 0 | 07-09-2006 12:55 PM |
