Results 1 to 3 of 3
Thread: Roland Space echo: Touchy Reverb
    Mar 2008
    1
    I'm a proud new owner of a Roland space echo 201.....
    My Problem is that the Reverb does not kick in until a bout the 3 level marker. At levels 1 and 2 the Reverb Volume level has no effect....Then at level 3 there seems to be alot of reverb...To much reverb....so it is kinda ALl or nothing with the reverb.....There is also a little hiss...but thats not my main concern....Any ideas what is causing the Heavy reverb at level marker 3?
    Thanks!
    Senior Member Enzo's Avatar
    Lansing, Michigan, USA
    18,046
    Disconnect the pot and check it with a meter.
    Mar 2008
    1
    just a quick note, the reverb on my re-301 is quite thick, pea-soupish. at three on the level knob it's already murky.
    if indeed the pot is the problem, try hitting it with contact cleaner. failing that replace it or ... open it up and clean the wiper with a pencil eraser.
  1. Roland Space Echo
    By JC@ in forum Maintenance, Troubleshooting & Repair
    Last Post: 09-09-2010, 10:35 AM
  2. Best setup for the Roland RE-201 space echo
    By mad dog in forum Guitar Effects
    Last Post: 01-24-2008, 07:04 PM
  3. Roland Space Echo RE 201 NO DELAY
    By kidinsane in forum Maintenance, Troubleshooting & Repair
    Last Post: 01-20-2008, 06:36 AM
  4. Roland Space Echo needs help
    By DeepSpace in forum Guitar Effects
    Last Post: 11-28-2007, 05:08 PM
  5. Roland Space echo
    By drewl in forum Maintenance, Troubleshooting & Repair
    Last Post: 03-31-2007, 05:00 PM
