Old 03-28-2008, 01:54 PM   #1
Acoustic 160 reverb hum
Hi,
turning on the reverb on my Acoustic 160 head creates lots of hum.The reverb is working (as weak as usual), the pot is ok. Changing filter caps, tubes, rev.cables and can did not fix it.Any ideas what parts to check?
Help much appreciated,
Zouto
Zouto is offline   Reply With Quote
Old 03-28-2008, 10:49 PM   #2
Make sure that the tank is oriented so the output side is as far away from the power transformer as possible.
52 Bill is offline   Reply With Quote
Old 03-29-2008, 07:39 AM   #3
And as a test for that, demount the reveb pan, and free its wires so you can hang it outside the amp cab far as possible from the power tranny. If it helps, Bill is right on.
Make sure the cables are plugged into the right jacks on the reverb pan. Pull the cables out of the jacks on the pan. With the amp running and the reverb turned up some, touch teh tip of each of those plugs with your finger. The one that makes hum out the amp speaker is the one to plug into the OUTPUT jack on the pan.
Old 03-31-2008, 12:04 PM   #4
Thanks
Thanks Bill and Enzo,
turning the tank so that it's output transformer is on the OT side reduced the hum to the normal level.
Zouto
Old 02-08-2009, 10:40 PM   #5
www.acousticcontrolcorporation.com
acousticcontrolcorporation is offline   Reply With Quote
Old 02-09-2009, 04:33 PM   #6
Senior Hollow State Tech
Bruce / Mission Amps's Avatar
More commercials?
Quote:
Originally Posted by acousticcontrolcorporation View Post
If you are going to take the time to type... why don't you participate instead of leaving your website URL?
How about just sharing some info like the rest of us.
Otherwise your just another annoying free commercial here and that is not in the true spirit of AMPAGE.
__________________
Bruce
Mission Amps
Denver, CO. 80022
www.missionamps.com
303-955-2412
Bruce / Mission Amps is offline   Reply With Quote
Help with Acoustic 470 drewl Maintenance, Troubleshooting & Repair 8 02-09-2009 04:34 PM
Need Acoustic 125 guitar ..pre amp please eddybruce Guitar Amps 1 02-08-2009 10:44 PM
acoustic pedal nick Guitar Effects 0 02-17-2008 02:52 AM
Acoustic 470 reverb issue gbono Maintenance, Troubleshooting & Repair 0 08-27-2007 03:54 AM
5E3 as acoustic / vocal amp elpops 5 E 3 12 08-29-2006 03:30 PM
