| Fun with computers Computer-related issues, like digital recording and stuff like that. |
| | #1 |
| Member Join Date: Feb 2007
| How to silence PC noises?
Not sure about your preference, but I prefer musical creativity away from vacuum cleaner type of noises... That's exactly how my PC sounded, before I put an end to it. Here's how: i) First, I removed and cleaned the big heatsink from the microprocessor. It contains a noisy, tiny fan. To reduce the noise of this fan one needs to reduce its speed by by about 15-20%, by inserting a low Ohm resistor in series with its power supply. ii) Next, I removed the big power supply box and its noisy fan, reduced its heights, by removing its cover and cutting down (using tin snips) its sides until almost even with the highest part in this box. Mine went slim to less than 2 inches! Caution: To protect against accidentally touching its parts I covered it with plastic grill. The whole box I then attached outside to the back of the PC so, that the opening of the power supply faces the PC' inside. iii) Into the empty space, previouly occupied by the power supply, I position a 7.5 inch or 18cm (in diameter) fan, made from a used cassette recorder motor and thin aluminum blades (from old persiana blades) glued onto the plastic capstan. I left the PC without its metal cover and covered it with a colored, decorative curtain, instead. Result: The PC stays cool and now is almost inaudible! Even the hard drives etc. benefit from the big, quite fan. Albeit the fan moves about 3 times as much air, due to its size and low velocity it generates no noise. Small fans are noisy, because they have to run fast in order to move the same air mass. I "stole" this idea from observing a household cooler fan... I'm enjoying this arrangement already for almost 2 years now. I'm not sure though, if this arrangement is suitable for a faster, more powerful system, but it certainly works with my lousy 1GHz Pentium PC. Picture: http://img2.freeimagehosting.net/uploads/0d1aa4046e.jpg Last edited by jjj; 03-29-2008 at 10:48 PM. |
| | #2 |
| Music Lover | |
| | #3 |
Yes, but mine is more down to earth and not modeled on abstract ideas. |
| | #4 | |
| Supporting Member Join Date: May 2006
| Quote:
http://www.youtube.com/watch?v=O_DgU92AuWE Many people are using notebook computers for recording since they are so quiet, but your solution works, too, if you are handy with tin snips! Thanks Steve Ahola Last edited by Steve A.; 04-12-2008 at 10:51 PM. | |
| | #5 |
| Senior Member Join Date: Dec 2008
A local studio recently came to me with the same problem...their Mac was way too noisy for in-studio use. I built an isolation box for it; basically a plywood box with gasketed doors on both ends and sound deadening padding inside. For cooling air, I mounted a pair of very quiet 5" fans in a chamber on the back door. The air moves in and out through labyrinth-type chambers on each end, which are also lined with padding. It works quite well, cutting out almost everything but a tiny bit of low frequency airflow noise. When they're doing something particularly quiet, they'll shut off the fans for a few minutes. |
| | #6 |
Another great way (if possible) is to place the PC in an adjacent room and feed all vital connections through the wall. The HDD on its own isn't noisy.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Loud tapping noises | Meowy | Pickup Makers | 2 | 02-16-2008 06:47 AM |
| What makes funny noises like this... | Ptron | Maintenance, Troubleshooting & Repair | 3 | 09-16-2007 01:10 AM |
| Vox AD30 noises | drewl | Maintenance, Troubleshooting & Repair | 3 | 05-19-2007 08:20 PM |
| Mesa Mark III silence | AtomicMassUnit | Maintenance, Troubleshooting & Repair | 3 | 11-09-2006 07:35 PM |
| 66 Bassman noises/problems? | Steve B | Maintenance, Troubleshooting & Repair | 15 | 08-17-2006 06:27 PM |
