| | #1 |
| Junior Member Join Date: Mar 2008
| Switchable Bass Boost for JCM900 Dual Reverb
So i just got back off nights and reading a bit of stuff on this forum. I came across this a while ago and decided to give it a go. http://web.aoct.org/marshall/jcm900-gain-mod.txt Im looking forward to hearing the results, and if anyone else here has done this already. I found some report dotted about saying they liked the changes this brought. I was reading and i got to thinking about adding switches to go to and from resistor values, or rotary switches to switch caps about in the tone stack. ![]() Anyway... that MASTERPIECE is something i just threw togther in ms paint. would something like that work? in theory, thats a 2 position switch going from the standard 100K value of R15, and what is meant to be the mod... only i replaced the 220K resistor with a 100K resister in series with a 100K pot (linear). the document says 470K defining the boost makes the bass flabby. so i thought id stick in the 100K safety resistor, so you have a familar start point, and then a varible resistor for varible bass boost. I could mount the pot on the front of the chassis (if it sounds good) and even add a pre-dist mid boost switch across R7 and a high-cut switch affecting R61 & C37. i could go switch mad and attach all the gain boost bits to a switch too. hopefully something pleasing to the eye. Anyway. if that sounds totally stupid/interesting let me know. this isnt to make my JCM900 sounds like an SLO or anything. its more out of interest than anything else! cheers! |
| | #2 |
| Junior Member Join Date: Dec 2008 Location: Istanbul, TURKEY
Have you performed the change you mentioned above? Would you like share its result with us?
__________________ JCM900 100W Dual-Reverb Combo |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Silverface Deluxe Reverb boost, any good ? | Paul P | Theory & Design | 1 | 11-22-2007 03:48 AM |
| Dual Professional Reverb Problems | locust | Maintenance, Troubleshooting & Repair | 12 | 10-04-2007 04:04 PM |
| Fender Dual Professional reverb help | fiesta55 | Mods & Tweeks | 6 | 08-09-2007 07:07 AM |
| JCM900 50w dual reverb low on power | Alex R | Maintenance, Troubleshooting & Repair | 24 | 07-19-2007 03:12 PM |
| Peavey 5150 Problem Diagnosis - Bass Boost/Power Supply | LOGANSTL | Maintenance, Troubleshooting & Repair | 4 | 03-03-2007 03:34 AM |
