3 custom made chassis and 2 production chassis I don't need.
I would like to sell these as a group, but if I don't get any takers, I will sell them individually. I will send photos of these on request.
2 each - made to order brass chassis. The brass is 1/16". The sheet metal guy didn't follow my drawings so I never used them. There is a lip on the wide ends that should really be removed to make them good for a head type amp. They are blank chassis. Dimensions are 22" X 4" X2 1/2". These are large and I originally intended to use them for Marshall JTM 45 type heads. If you are interested in these I'll send a photo which will explain the lip.
1 each - custom built Fender Tweed Twin style chassis, that is close to the original dimensions, but a little longer. This was for a custom amp that a customer backed out on. It was made by Komboking from .080 aluminum with welded corners and very well constructed.
Dimensions are 22" X 4" X 2.5" There is a 1/2 inch lip running the length on one side. It is a blank chassis.
1 each Stancor CH-2133 chassis. I picked this up at a swap meet and cannabalized the parts for other projects. It is steel, copper plated and painted metalic gray on the outside. It is punched for a tranny, tubes and can caps.
1 each - 11" X 7" x 2" Kelvin aluminum blank chassis. This is a simple "U" shaped chassis with open ends I got from the now defunk Kelvin Electronics long ago. Good for a simple champs style amp.
If interested contact me at eyeluvcisco2000@yahoo.com
