| | #1 |
| Member Join Date: Mar 2008
| MARK IV EQ Scaling
Hi, You all know that those inductors are hard to get. In the same time there's a wide selection of inductors of up to 100mH so I was thinking of scaling down the tone control section by a factor of 10. The values for the 80Hz section for example will be: OLD - NEW 470 Ohm - 47 Ohm 1H - 100mH 3.3uF - 33uF pots 50k - 5k Did I get it right and do I need to tweak the circuit any firther to make it work with the new values? |
| | #2 |
| Senior Member Join Date: Jun 2006
Since it's a solid state EQ anyway, perhaps it's easier to use opamps instead of inductors? It should be fairly easy to find a schematic for a generic opamp-based graphic EQ, and adjust it to get the desired frequency bands. E.g. something like this: http://www.generalguitargadgets.com/pdf/ggg_eq6b_sc.pdf |
| | #3 |
| Supporting Member Join Date: May 2006 Location: Glasgow, Scotland
You scaled the characteristic impedance of the tuned circuits by a factor of 10, so you'll need to reduce every other impedance in the circuit by a factor of 10 too, and make sure any active devices can source 10 times the current that they had to before, and have 1/10 the output impedance. The smart money is indeed on replacing all those inductors with gyrators.
__________________ "Ohhhh miracle bulb shines feebly" |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Power Scaling is Flawed? | tbryanh | Theory & Design | 157 | 02-13-2010 07:09 PM |
| Scaling Bridged-T tone circuit | Steve A. | Guitar Amps | 4 | 07-15-2008 05:57 AM |
| Stepped Power Scaling? | tbryanh | Theory & Design | 8 | 10-06-2007 07:23 AM |
| Mark IV EQ | Gregg | Theory & Design | 4 | 03-22-2007 10:43 PM |
| Power scaling | Ptron | Theory & Design | 2 | 08-21-2006 02:37 PM |
