Go Back   Music Electronics Forum > Amplification > Guitar Amps > Mods & Tweeks
Old 04-10-2008, 11:47 PM   #1
resistor types
do different types of resistors effect the sound of a guitar amp. I have a Crate VC50 3x10 amp and it has metal oxide resistors in the power amp section. How would it change the sound if i installed carbon composite resistors like Allen Bradleys?
thanks
keith
baddog is offline   Reply With Quote
Old 04-11-2008, 12:12 AM   #2
Supporting Member
I don't know about the tone, but metal film resistors are good for reducing (or virtually eliminating) hiss when you use them as plate resistors. I think they come in 0.6W, so if you want more power you can put a couple in parallel for each plate resistor.
RG Keen's website has a blurb about the mojo of carbon comp resistors.
Old 04-11-2008, 03:26 AM   #3
Mouser (in the US) sells metal film resistors up to 10w (at 5$ each).
Paul P
Paul P is offline   Reply With Quote
Old 04-11-2008, 07:29 AM   #4
I'm guessing (just speculation) that to get the "mojo" out of carbon comp, you need them in a stage that is driven really hard. I.e. if you put them in a typical master volume amp that doesn't drive the poweramp hard, all you get is more hiss.
d95err is offline   Reply With Quote
Old 04-11-2008, 05:14 PM   #5
The general rule is carbon comps have better tone and are noisier than metal film, which are much less expensive.
Many vintage Fender amps builders often use carbon comps exclusively, although some may use metal films in specific places to reduce hiss.
Modern mass production amps often use metal films to reduce costs.
Some boutique amp builders use them to get a certain type of clean sound (carbon comps have a more blues sound). For example, Dumble amps use metal films.
Of course, all of these statements are generalizations.
__________________
See the birth of a 2-watt tube guitar amp - the "Dyno Tweed"
http://www.naturdoctor.com/Chapters/Amps/DynoTweed.html
PRNDL is offline   Reply With Quote
Old 04-12-2008, 10:44 PM   #6
I've never used carbon comp resistors in my builds, rebuilds or repairs. No one has ever demonstrated to me that carbon comp resistors sound better than any other type. There seems to be a LOT of "botique" builders who want to justify their existence and high prices by continuing this myth, or they don't really know - so they just put their finger in the air and say - "this is what's selling today". Metal film resistors are less expensive (now) because of supply & demand economics. There are a LOT more metal film resistors sold these days than Carbon Comps. In the 50's and 60's 1% metal film resistors were less plentiful and much more expensive than the generic common Carbon Comp. CC resistors were not selected by amp manufacturers for tone - they were selected because they were cheap and easy to find. Now they are much more expensive so in order to justify the cost in a "clone" amp there has to be some mystical, magical tonal quality attributed to them.
No need to repeat myself here....
Metal films are more expensive than Carbon Film, which is used by most major manufacturers. Metal film resistors are used to control variances in production, often by high-end high-gain builders like Mesa, Soldano or Bogner. Most MF's are 1% tolerance. Using tight tolerance components makes for more consistent tone from one amp to another. The low noise factor is an added plus.
And Dumbles aren't played by any Bluesy players???
Understood - I just wanted to share my take on this subject.
RE
Last edited by Rick Erickson; 04-12-2008 at 10:47 PM. Reason: Like I need a reason?
Rick Erickson is offline   Reply With Quote
Old 04-12-2008, 11:48 PM   #7
Supporting Member
Steve A.'s Avatar
Quote:
I've never used carbon comp resistors in my builds, rebuilds or repairs. No one has ever demonstrated to me that carbon comp resistors sound better than any other type...
Okay, throw out the word "better"... I know a lot of roots players who prefer carbon comp resistors because they are noisier. They also seem to prefer single coil pickups because they are noisier, too. Go figure...
When you add up the noise from the single coil pickups to the noise from the CC resistors, you probably aren't going to crank up the gain of your rig to heavy metal extremes.
I was listening to Jimi Hendrix one night (this was a recording, not the man! ) and it occurred to me that part of his sound was due to the noise coming from the single coil pickups. Namely, if you were to put Kinmans in his guitar, it just wouldn't have sounded the same...
Of course after that night my doctor changed my meds so I have had not any further revelations about Jimi Hendrix or single coil noise.
Steve Ahola
P.S. I only buy metal film resistors these days- who needs more noise? They are dependable and accurate- although pricier than carbon films if I were to buy them in bulk. And I've read a few posts here that say that carbon film resistors are almost as quiet as metal film ones, although you might want to use metal film for plate resistors... Thanks for your very informative posts!
Steve A. is offline   Reply With Quote
Old 04-13-2008, 10:28 PM   #8
ANd I would think the application makes a difference. The high gain input stages where the signal level starts out tiny will be a lot more sensitive to noise from a resistor than something like the cathode resistor in the output stage. I don't worry much about noise in the power amp coming from resistors.
Old 04-13-2008, 10:29 PM   #9
Pedro Vecino's Avatar
Mesa uses a big quantity of carbon comp resistors in the Lonestar.
Regards
Pedro Vecino is offline   Reply With Quote
Old 04-13-2008, 11:36 PM   #10
Here is the whole subject, scientifically treated and wrapped with a bow.
http://www.aikenamps.com/ResistorNoise.htm
http://www.geofex.com/article_folder...carboncomp.htm
AFAIAC, any anecdotal, subjective, mojo-ridden discussion about the tone of CCs beyond the above two sources is almost guaranteed to be largely BS.
Ben N is offline   Reply With Quote
Old 04-14-2008, 08:10 PM   #11
I use single coils in my Strats & Tele's, but they have reverse-wound Center (Strat) & Neck (Tele) pu's in them.
I was listening to Jimi Hendrix one night...
I was talking to Randy Hansen a few weeks ago. That's about as close to Jimi as we can get around here since Al passed away.
RE
Old 04-22-2008, 09:13 PM   #12
I didn't believe all of the CC hype until I took two identical amps I built and swapped in CC resistors in crucial places. Man, was THAT an eye-opener! It's not hype. CC resistors DEFINITELY give the amp more feel. And I just did the preamp! I left the PI alone with CF resistors. Can't say that I noticed any more noise. CC's are noise-prone as the carbon block ages and takes on moisture from the surrounding environment.
Critical places for CC are signal path and load. This encompasses series signal resistors (including grid stoppers), cathode resistors and plate resistors.
Here at our shop in NYC, we stock CC's to use in vintage repairs. If a CC comes out, a CC goes in. I'm convinced it's real.
__________________
John R. Frondelli
jrfrond is offline   Reply With Quote
Old 05-03-2008, 08:59 PM   #13
Metalfilm is more transparent and carbon is not.
In high gain amps the carbon hizzes lika a f... snake.
I love metafilm because i lets all the colour of the guitar and the tubes through.
The same for polypropylen caps.
But carbon and polyester is colouring the sound more, that is true.
Tubis is offline   Reply With Quote
Old 05-03-2008, 11:59 PM   #14
HTH
HTH's Avatar
My AC20 build sounded quite flat and lacking sparkle until I replaced the 1w CFs with CCs.
I wouldn't use CCs for everything, but it's worth trying them out and deciding for yourself.
__________________
HTH - Heavier Than Hell
HTH is offline   Reply With Quote
Old 05-04-2008, 12:25 AM   #15
bulldogguitars's Avatar
What about the carbon film resistors. Wouldnt this be the best of both worlds. Just askin.
bulldogguitars is offline   Reply With Quote
Old 05-05-2008, 06:33 AM   #16
Senior Hollow State Tech
Bruce / Mission Amps's Avatar
Quote:
Here is what was just said in the post above yours...
"AC20 build sounded quite flat and lacking sparkle until I replaced the 1w CFs with CCs."
I don't know what an AC20 is but I can tell that from my perspective I have never heard a CC resistor set make an amp sound better... especially more sparkle.
However I have had a number of amps (mostly helping home builders) with wrong value or misread CF resistors in them, sound very good with the correct value CF resistor.
__________________
Bruce
Mission Amps
Denver, CO. 80022
www.missionamps.com
303-955-2412
Bruce / Mission Amps is offline   Reply With Quote
Old 05-05-2008, 07:02 AM   #17
Quote:
Originally Posted by Bruce / Mission Amps View Post
.....but I can tell that from my perspective I have never heard a CC resistor set make an amp sound better... especially more sparkle.....
With my experimentation, it was not sparkle that was gained. In fact, very little about the actual tonality changed. It was all feel, a certain "bounce" that was not as prominent before, somewhat akin to opening a negative feedback loop, except that the test amps use no NF, and already had that feel. FWIW, the amps were built with CF.
__________________
John R. Frondelli
Old 05-05-2008, 10:38 AM   #18
HTH
HTH's Avatar
I call it an AC20 because it's just a top-boost Vox preamp into a pair of cathode biased 6V6s, hence AC20. It's a cool sounding little amp, really fat and grindy.
I don't know why the tone changed, but I know what my own ears tell me.
I've got other amps that have sounded great with CF and MF resistors, so CC are not the magic ingredient or anything, just happened to make a difference on this specific amp of mine.
__________________
Old 05-17-2008, 03:54 AM   #19
cminor9's Avatar
I read this: http://www.geofex.com/article_folder...carboncomp.htm This article does mention that there is benefit to using CCs, namely, resistor distortion. I am a big fan of "it means nothing if you can't measure it" when it comes to electronics. According to the article, CCs do provide a measurable effect. Now whether it makes a sonic difference or not, well, I guess that's wide open. I have always read that CCs will aid in giving a nice swirl, and when you read this page I think it makes sense as to why.
The main conclusion that I drew from this article was that using CCs on cathodes is bad, and using them on input stoppers and for the bright inputs is also bad and provides little sonic value.
I recently built a 5E3 using all carbon comps. This afternoon, I spent some time replacing the 68k input stoppers, 1meg bright inputs, 820 ohm cathode resistor on v1, and the 1500 ohm cathode resistor on v2a. I left the 100K plate resistors alone only because I didn't feel like removing the board in case my B+ lead came out. The hiss that was there before is almost completely gone. I have read posts on here stating that the 5E3 should not hiss, but mine did (no hum, just hiss). Replacing the CCs as described really cleaned the amp up a lot.
Still get nice swirl, a good warm tone, etc, just much quieter. I think I'll keep using metal films on mostly everything before the PI on new builds. It really made a difference in all the right ways. Oh, and for cost, the metal films cost much less. I get them from Antique Electronic Supply for $1.5 for five, compared with $2 - $2.5 for five CCs.
__________________
Shiny package of rusted wreckage
Fender Schematics Galore at http://ampedia.redbeartrading.com
cminor9 is offline   Reply With Quote
Old 05-17-2008, 09:27 PM   #20
Yea, the CC is not quite linear so some distortion is the result. Note that some caps do the same thing. Ever noticed the crisp that cheramic caps tend to give to the treble?
Old 05-18-2008, 12:16 AM   #21
Based on the non-linearity argument, these are the ones that should stay carbon comp. They have a large voltage swing on them, they're high value, and a bit of noise won't get amplified (more likely, it will get attenuated). Thanks for reporting your results. Hiss is much easier to accurately note changes in compared to "sparkle".
Me? I like to play clean, and I value dynamic range highly. Hiss bad.
BackwardsBoB is offline   Reply With Quote
Old 05-20-2008, 03:44 AM   #22
resistor type
I changed all of the 1/2 watt & 2watt CF resistors with CC resitors and noticed a big diferance. alot brighter and fuller and it was plain fun to do. I wonder what would happen if i changed out all of the metal poly capcitors with orange drops or mylar caps.
Old 05-20-2008, 07:22 PM   #23
Quote:
Hmm, aint those caps also polyester.I dont think you would hear much difference. If you switch to another material like polypropylen maybe. Or did you mean that by the short poly?
Old 05-20-2008, 09:01 PM   #24
resistor type
Im not sure it would make a diferance in the sound either. I do have some vintage ceramic disk capacitors that i installed in a varitone switch and installed it on one of my guitars and there is a big diferance in tone from brand to brand . some have creamier tone and some just sound muffled. Im not sudjesting using them as a replacement for all of them just in the tone control area. Or if anyone has any ideas where to install them in my crate VC50 it would be apreciated. see attached schematic of the preamp
thanks
baddog
I have changed all transistors.diodes,zener diodes, 5watt resitors ,1/2watt & 2watt resitors with CC and installed new filter capacitors with standard size ones not the mini pieces of crap they came with.
Old 05-20-2008, 09:24 PM   #25
Ceramic disks come in different classes. Class 1 is more linear than class 2 so that makes a difference. The most effekt is in the treble filters. A class 2 ceramic will make the treble more crispy.
Man, English is hard. I´m from Sweden
Old 05-11-2009, 03:27 PM   #26
Your English is excellent. Grammar and spelling as good as any native.
mbratch is offline   Reply With Quote
Toxic wire types? NightWinder Pickup Makers 6 02-19-2008 06:18 PM
weicowire.com and wire types? nickt Pickup Makers 7 11-29-2007 04:16 AM
Types of Fuses? jhares0311 Maintenance, Troubleshooting & Repair 2 11-06-2007 03:50 AM
General guidelines for types of wire used... ZBod Vintage Amps 5 04-14-2007 07:19 PM
types of delay jbmorse02 Guitar Effects 1 01-08-2007 04:19 PM
