Old 04-12-2008, 05:53 PM   #1
Marshall valvestate 8080 how to get more reverb
Hi all:
I've just bought a secon hand valvestate 8080.
It sounds "great" but the reverb was very low comparing to my 8280 valvestate.
I changed three resistors in the reverb section and put in the following:
R90 and R91: 1M ohm, R92: 100K Ohm.
This helped get better/more reverb effect.
korhipt is offline   Reply With Quote
Old 04-12-2008, 06:02 PM   #2
Rather than modifying the circuit, did you consider repairing the existing circuit? perhaps you had a weak drive.
Old 04-18-2008, 06:13 PM   #3
I changed both op amps before and after the reverb tank. It didn't help. I didn't take much time checking the signal i have to say, since i already had these two op amps lying around. tl072 and rc4558. i took a chance But the reverb signal was weak anyhow. Maybe the 5201 didn't switch properly, i don't know, but i'm pleased with the result as it turned out.
Valvestate 8080 bass bug BrainDamage Maintenance, Troubleshooting & Repair 2 04-07-2008 01:59 AM
Valvestate 8080 Troubles WMK Maintenance, Troubleshooting & Repair 6 02-07-2008 01:17 AM
Marshall Valvestate 8080 intermittent volume dips cosrjc Maintenance, Troubleshooting & Repair 2 01-02-2008 11:37 PM
Marshall Valvestate 8080 Muddy, Scratchy and Noisy Pigyboy Maintenance, Troubleshooting & Repair 14 12-10-2007 05:31 PM
Noisy valvestate 8080, and help finding a debuging page? Satamax Guitar Amps 4 05-21-2007 01:00 PM
